Results 1 to 8 of 8
Thread: Too big?
    Default Too big?
    Looking at a set of axles Crum a f550. Dana 60 kp front and dana s135 rear. Around 72" so they should fit. My question is, is the s135 too much for the 715. I plan to run bead locks, maybe a touch bigger. Just a good deal on these so wanted to ask you guys first before committing. Thanks
    4.88 gearing...
    Feb 2007
    Bloomfield CT
    If duce axles are not too big, I see no problem with those as long as it clears and you cam mount the springs...
    Is that real money?
    Sep 2014
    Southern New Hampshire
    No such thing as too big, to small maybe...
    You'll be fine as long as springs are properly mounted, and the rims clear the bed/frame.
    Sent from my SM-S920L using Tapatalk
    At 72" wms to wms, I don't see an issue with wheel clearance. Do you?
    Thanks for the reply.
    Dana 60 Kingpin Front, Ford Sterling 10.25 rear here...
    Hope you have a powertrain upgrade... stock tornado motor is not going to like spinning beadlocks with big tires.
    12 valve with Allison trans. I should be good there.
