  #21
Old January 15th, 2018, 11:23 AM
Rtech1841 Rtech1841 is offline
New Recruit
Rtech1841 is a Soldier
Default Oil filter issue
I finally got my truck running. How ever after running for a few seconds it starts to spray oil from the oil filter (enough for a possible epa call) the filter is the Napa 1515 that's recommended the oil is SAE 30. It seem like the oil pressure is too much and blowing the seals out of the filter. Has anyone else had this problem and what can I do to fix it?
  #22
Old January 15th, 2018, 02:11 PM
Jonnie's Avatar
Jonnie Jonnie is offline
Jonnie is a Soldier
What's the pressure on the oil gauge?
Jonnie
  #23
Old January 15th, 2018, 04:26 PM
New Recruit
gauge has it coming in around 80.
  #24
Old January 15th, 2018, 05:44 PM
28chevys 28chevys is offline
New Recruit
28chevys is a Soldier
Sounds like you oil pump by pass valve is stuck.
  #25
Old January 19th, 2018, 07:22 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Not trying to be a smarty pants but dd you make sure that the gasket from the old filter wasnt stuck to the truck when you put the new one on? I havent done that but others have and have reported this kind of problem...maybe its that simple...I hope.
  #26
Old January 20th, 2018, 08:21 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
Certainly worth looking into. I became aware of that many years ago and it is my standard to always look at the filter on any vehicle to be sure that it is still on the oil filter. I have seen more than one situation where the "O" ring gasket was not present on the old filter and there it was, stuck to the engine.
  #27
Old January 20th, 2018, 11:18 AM
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
My oil pressure maxes out at 60 psi, so I'm thinking the pressure relief valve is stuck.
  #28
Old January 21st, 2018, 11:13 PM
New Recruit
i did. im pretty sure the where the oil returns to the engine from the filter is clogged. causing the filter to over pressurize
  #29
Old March 6th, 2018, 03:02 PM
New Recruit
Default Registration
I'm having some issues insuring and registering my 68. They need a vin and I can't seem to find one. Is it different because it's military? Where should I look?
  #30
Old March 6th, 2018, 04:19 PM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
Should be on the data tags or on the passenger front frame horn on top if i am not mistooken....
Is that real money?
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
