  #51
Old September 28th, 2015, 06:23 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
Quote:
Originally Posted by wolf.dose View Post
Without reading me through all the replies: the M715 series has no long and no short lining on the brake shoes, for it is a duo-servo brake. The original thickness is 1/4 inch. If you get your brake shoes relined, ask for 7 mm thickness. This will equalise the wear of the brake drums.
33 years with a M715 and 98000 miles.
greetings
Wolf
Wolf, I have two sets of shoes. One set has primary and secondary shoes; the others are the same size. I installed the primary/secondary set on the front and the set that is the same size on the rear axle. I guess it depends on where you get them relined.
  #52
Old September 28th, 2015, 08:09 AM
rboltz's Avatar
rboltz rboltz is offline
Sergeant
rboltz is a Soldier
Default Nos
Quote:
I bought NOS shoes and they are like Don says. I also have NOS linings on the shelf and they are different lengths also.
Does it matter much? Don't know.
__________________
  #53
Old September 28th, 2015, 03:15 PM
Don Cavey's Avatar
Staff Sergeant
I know that for decades working on drum brakes, the primary or short shoe went towards the front of the vehicle. Not sure of the engineering. But my other shoes are of the same length. Since the front brakes do the most work, I put the primary/secondary shoes on the front. Believe me, my truck will stop very quickly with my single master cylicnder and standard (not power) brakes.
Just my experience, not a recommendation ...
  #54
Old September 28th, 2015, 09:21 PM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
If you look in the online maintenance manuals, the brake section tells the long short part...so does the Quirks manual...
Quote:
GIVE ‘EM A BREAK
Brake shoes on your 5-quarter are different from what you’ll find on other tactical wheeled vehicles — the front, or primary, shoe in each wheel has a shorter lining than’s on the rear shoe. Make sure you install ‘em that way— and they’ll give you a brake.
From here:
http://www.m715zone.com/vb/view.php?pg=quirks
__________________
  #55
Old November 5th, 2015, 04:20 PM
wolf.dose's Avatar
wolf.dose wolf.dose is offline
Private 1st Class
wolf.dose is a Soldier
Hallo together,
when I first time rebuilded my M715, the lenght of the brake shoe lining was front and rear the same. Technically this makes sence, for it is a duo-servo brake, which forward and reverse supplies the same brake force with the same brake pressure. The only problem with this brake designe is the variation of the friction factor of the brake linings. Therefore it is very difficult, close to impossibel, to set the brake forces on the brake roller test bench to the same braking forces.
When you get your brake shoes relined, always install per axle a new set. Else your problems with brake drag will never stop.
33 years with a M715 registered.
greetings
Wolf
  #56
Old November 5th, 2015, 04:29 PM
wolf.dose's Avatar
Private 1st Class
Hallo together,
May be the brake shoes you have installed are fron a Gladiator truck. The so called simplex Brakes have differnent length of the brake shoe lining to avoid overbraking of the rear axle. To avoid his problem I installed 15/16 rear brake slave cylinders. Since then I have a real good stopping power.
greetings
Wolf
  #57
Old December 19th, 2015, 09:07 AM
mustang mustang is offline
Civilian
mustang is a Soldier
Quote:
Originally Posted by brute4c View Post
There is a way to adapt a civilian shoe....this is a repost from WetCJ:
What was the brake shoe companies name I looked at Raybestos with the Number #60 nothig came up..
  #58
Old December 19th, 2015, 08:06 PM
brute4c's Avatar
Grand Poobah
Using the TS60 NAPA shoe info above I found this...
Brand:RAYLOC
Part Number(s):TS60
Try that and let us know if it works...
__________________
  #59
Old December 19th, 2015, 08:10 PM
brute4c's Avatar
Grand Poobah
Found this as well:
RAYLOC TS60
RAYBESTOS 60PG
CARQUEST BS273
AutoZone 60PG
Make Model Year Engine
DODGE D200 PICKUP 58-57 All
DODGE D300 PICKUP 59-57 All
DODGE D300 PICKUP 71-68 All
DODGE D300 SERIES 67-60 All
DODGE P300 71-61 All
DODGE P300 SERIES 1959 All
DODGE P300 VAN 1961 All
DODGE W200 PICKUP 59-57 All
DODGE W200 SERIES 1960 All
DODGE W300 PICKUP 59-57 All
DODGE W300 SERIES 64-60 All
FORD F-350 PICKUP 66-53 All
FORD P-350 66-56 All
Hope that helps...
__________________
  #60
Old June 25th, 2017, 04:56 AM
ray steadward ray steadward is offline
Private 1st Class
ray steadward is a Soldier
My NAPA comes up with nothing for a TS60, trying the TS320 also mentioned today. Chevy P30 van cross. Mikel just gave me the skinny on a relining shop that is pretty close (in Portland CT) too...
Maybe I missed it, but did anyone give an application for the #451 autozone shoes?
__________________
Is that real money?
Tags
brake shoes
Brake shoes for dummies fng Stock Tech 18 July 27th, 2014 11:07 AM
oilcan : modified modern brake shoes for stock axles oilcan PseudoZone - Open Archive 4 November 11th, 2009 12:06 AM
Front brake shoes wet... Fastfrankie Open Discussion 5 August 17th, 2009 06:23 PM
wheel cyl and brake shoes need angler Modified Tech 3 May 21st, 2007 08:07 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
1998 - 2018
Copyright 1998-2018
