Results 1 to 4 of 4
Thread: Body Bushings
    I por15 my frame and my cab and bed are just resting on my frame with some bolts dropped through. I would like to replace the rubber body bushings. I've heard some people have used drilled out hockey pucks as a cheap, stong way of doing it. Also I remember a posts a few months ago about use of poly bushings from possibly a CJ kit. What are people using?
    Scott
    I used the rubber bushing from a CJ fiberglass body kit. Cut it to the thickness you want. It's comes in a 2 foot length.
    John
    Washington State
    John does the cj body kit have rubber or polyurethane ? Is it solid ? Could you use it for a body lift possibly? Thanks Fisherman
    It is rubber. I think the outer diameter is about 3"and it has 1/2"-5/8 hole through the center. I used it for the cab mounts (3/4" thick). I don't think I would use it for a 3" body lift'maybe 1".
    http://www.4wd.com/shopwrangler/Disp...roductSKU=5000
    John
  1. luckypabst : Poly body bushings
    By LuckyPabst in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 05:21 AM
  2. tie rod bushings
    By shipman in forum Open Discussion
    Last Post: February 13th, 2009, 02:32 AM
  3. Spring bushings?
    Last Post: February 12th, 2009, 11:43 AM
  4. Durometer for body bushings??
    By Snuffy in forum Open Discussion
    Last Post: October 17th, 2008, 05:53 PM
  5. Body bushings
    By Chumley in forum Stock Tech
    Last Post: September 26th, 2007, 03:13 PM
