  #51
Old September 9th, 2017, 10:58 PM
tomb's Avatar
tomb tomb is offline
Private
tomb is a Soldier
wheel cylinder replacement
m715 150 by tom boyer, on Flickr
I have seen wheel cylinders that look like this on this site. what makes them rust when the rest looks so good.
m715 148 by tom boyer, on Flickr
  #52
Old September 10th, 2017, 08:21 AM
Von's Avatar
Von Von is offline
Corporal
Von is a Soldier
All 4 of mine looked like that. Surprised the silly thing was stopping at all.
In one of the brake threads Don or Dan or one of the other gurus said something about the material used in the bore lining of the OEM cylinders...? Something like that. They were also talking about relining the cylinders so I might have misunderstood.
I remember the cups felt awful light when I took one apart. I was expecting a little chunk of steel and it felt like some cheesy pot metal.
I'd done a boatload of brake work over the years and never seen wheel cylinders as bad as what I've seen on my truck and posted on this site.
  #53
Old September 10th, 2017, 11:49 AM
brycer1968's Avatar
brycer1968 brycer1968 is offline
Private
brycer1968 is a Soldier
Default Wheel cylinders
Yes, mine looked just like that too when I pulled them off.
I cleaned them up and had them bored and lined with stainless steel sleeves by a local place here in Washington state. I think its either that or a dot5 silicone fluid conversion - or maybe both that should keep your wheel cylinders looking and working like new.
__________________
1969 M725 ambulance
  #54
Old September 10th, 2017, 06:16 PM
tomb's Avatar
Private
tomb is a Soldier
I used replacement wheel cylinders from carquist had to long gate the bolt holes a little.
right side cwh wca 18985
left side cwh wca 18984
  #55
Old September 13th, 2017, 10:30 PM
tomb's Avatar
Private
tomb is a Soldier
flicker is no longer working
  #56
Old September 15th, 2017, 07:44 PM
tomb's Avatar
Private
tomb is a Soldier
flicker is back on stanless brake lines
m715 154 by tom boyer, on Flickr
m715 153 by tom boyer, on Flickr
m715 155 by tom boyer, on Flickr
  #57
Old September 19th, 2017, 07:00 PM
tomb's Avatar
Private
tomb is a Soldier
cab on cart
m715 156 by tom boyer, on Flickr
cab striped
m715 159 by tom boyer, on Flickr
my one rust hole
m715 160 by tom boyer, on Flickr
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
1998 - 2016
Copyright 1998-2016
