Results 1 to 7 of 7
Thread: airborne : steering box bolts,
    Huntingtown,Md.
    Default airborne : steering box bolts,
    steering box bolts,
    Post by airborne on Jun 18, 2006, 12:34pm
    what did everyone else use to remove the top steering box bolt? I've tried my 1/2" ratchet and 5/8 socket no room to work the ratchet. It is a fine tooth flex head. Stupid ?
    Washington State
    Default fisherman :
    Re: steering box bolts,
    Post by fisherman on Jun 18, 2006, 12:48pm
    I did my power steering conversion last year, as I recall that one tooka wobbly socket to remove. It wasn't easy, but it also wasn't that difficult. Soak the bolt with PB blaster at least 3 times over 3 days, it more than likely will come right out. Welcome aboard. Fisherman
    Huntingtown,Md.
    Default airborne :
    Post by airborne on Jun 18, 2006, 12:50pm
    Never mind going to try another ratchet a friend has. Says it works on fsj.
    Huntingtown,Md.
    Default airborne :
    Post by airborne on Jun 18, 2006, 1:00pm
    Fisherman, Thanks for posting,I needed the input. I can get it to move but only one click at a time. I don't have a "wobbly" socket,guess I'll go buy one for Fathers Day. Everything else is coming apart so easy,even the junk yard fsj box came right off! Guess I got lulled into thinking it was going to be easy!
    Washington State
    Default fisherman :
    Post by fisherman on Jun 18, 2006, 1:04pm
    Just figure everything is going to be a PITA and difficult. Use lots of PB blaster on rusted parts. You'll be surprised at how easy things will come apart. Fisherman
    Atlanta, Ga.
    Default bluesman2a :
    Post by bluesman2a on Jun 18, 2006, 11:09pm
    On mine I used a deep-well to get in there on the initial, but once you get it out a bit you need to change to a normal socket or you can't get it out. Not much room to work so I opened it up a bit with the old plazzzz-maaaa and now I can get an air ratchet in there just fine.
    Huntingtown,Md.
    Default airborne :
    Post by airborne on Jun 19, 2006, 6:30am
    Thanks all. Got it out, NOW all I have to do is reinstall it. Looks like even more fun! This will get new bolts and washers for sure. NOT going to try this anymore than I have to! LOL!
  1. airborne : Shocks,
    By airborne in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 04:46 AM
  2. airborne : Dana 60
    Last Post: November 12th, 2009, 02:12 AM
  3. airborne : Power steering
    Last Post: November 12th, 2009, 12:26 AM
  4. airborne : P/S pump overhaul
    Last Post: November 11th, 2009, 04:38 AM
  5. airborne : Power steering hoses,
    Last Post: November 11th, 2009, 03:56 AM
