Results 1 to 5 of 5
Thread: springs
    Exclamation springs
    can any one give the measuerment of the front and rear springs
    Washington State
    Which measurement do you need? The length or the width?
    What measure you want?
    Spring eye to eye?
    Spring eye diameters, ID or OD?
    Overall length?
    Thickness?
    Width?
    Length of each leaf?
    Other?
    I have a set of NOS springs in the shop...all 4...let me know where to stretch the tape.
    eye to eye measurement and the spring eye hole what size bolt does it take and could you pull a line from eye to eye and measure from the line down to the bottom of the spring pack thanks any help will be great .... looking for lift springs i work at a 4x4 shop in atlanta . will let everyone know what i find out .......... lee ...................
    OK....here we go:
    eye to eye measurement, center to center:
    Front spring: 41½ inches
    Rear Spring: 50 3/8ths inches
    spring eye hole what size bolt does it take:
    Front: Hole in bushing is .567 inch....just over 9/16ths
    Rear: Springs do not have a bushing in them like the front, the hole in the spring eye is 1 inch. The pin on the frame that the spring goes on is .858 inch.
    Line from eye to eye and measure from the line down to the bottom of the spring pack:
    Front: 8.60 inch
    Rear: 8.875 inch
    Let me know if that isnt clear or you need more.
  1. coil springs and leaf springs ?
    Last Post: April 4th, 2010, 01:13 PM
  2. stock leaf springs vs custom leaf springs
    By japsk8 in forum Modified Tech
    Last Post: December 11th, 2009, 01:02 PM
  3. Lift Springs
    By Troop ISP in forum Modified Tech
    Last Post: September 12th, 2009, 09:27 PM
  4. Big Springs
    By jeepjunker in forum Modified Tech
    Last Post: July 7th, 2009, 11:55 PM
  5. Springs
    By carmen in forum Open Discussion
    Last Post: January 17th, 2007, 01:31 PM
