Results 1 to 2 of 2
Thread: Need spark plug wiring diagram
    Question Need spark plug wiring diagram
    I was changing the spark plugs on my 1967 M-715 Inline 6-cyl, 24 volt system and I managed to get the plug wires mixed up. I wanted to know if someone might have a spark plug wiring diagram for my truck. I would greatly appreciate any one who would help me in this mess I've gotten myself into. Thank you. My e-mail address is below:
    dwh81@yahoo.com
    OK...heres all the info I think you need:
    First, the wires go on the ignitor/distributor end in a counter clockwise direction.
    The firing order on the plugs is 1-5-3-6-2-4.
    If you have lost track of which one is number one:
    Take out the #1 spark plug and rotate the motor, have someone crank it just a bump at a time or by using a socket on the crank pulley, until the compression in the #1 cylinder blows your finger off the hole.
    Look at the timing marks and rotate till the engine is at TDC...you can also stick a straw/screwdriver/pencil/etc. in the #1 plug hole to make sure that the piston is as high up as possible.
    Take off the top of the ignitor housing and look where the rotor is pointing.
    The corresponding plug wire on the cap that the rotor is pointing to is #1.
    Put the #1 plug wire on that tower and connect the rest of the wires in the order of the firing order in a counterclockwise direction.
    Clear?
    If not, let us know what isnt clear or what you need that isnt covered...no sweat.
  1. barrman : Wiring Diagram
    By Barrman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 12:15 AM
  2. Wiring diagram for spark plug wires - HELP!
    Last Post: March 22nd, 2007, 12:54 PM
  3. M715 Wiring Diagram ?
    By Nuke_Danarchy in forum Open Discussion Archives
    Last Post: February 27th, 2004, 07:44 PM
