Results 1 to 5 of 5
Thread: Gas pedal ball studs
    Default Gas pedal ball studs
    Ok my throttle pedal has never felt right since I got the M715 about two weeks ago I pulled it apart and let me tell you it was in bad shape. The two ball studs that come up from the floor where rusted and bent beyond repair. So I got the FSN/NSN number for them and tried to find them on the net. I searched for about a week and then just on a whim I called Memphis equipment. The guy took a second to think then said ya we have those since I needed a carb kit I just ordered everything from them. They came yesterday and I thought looking at them they where going to be horible to try and get out I envisioned drilling,heat,etc. I went out today and used a set of vice grips and they came out as easy a new bolt. I installed the new ones with nice lock washer and anti-sieze and I must say my gas pedal has a much better feel to it now.
    Here are some shots of the old ones.
    Wish I had knew that Memphis had those.
    I ended up welding round stock onto a bolt and then turning it down to make the ball portion. While I was at it I made a new mounting plate too.
    Here's the old and new
    Pic of the ball stud before trimming to length
    If I ever get my truck running, maybe I will actually experience the improvement in pedal feel.
    Nice job yours looked a lot better than mine to begin with LOL.
    At this point, I have absolutely no idea of part numbers or the exact application, but I carried the best of my studs to NAPA, counter guy went right to the back, and came back with a pretty close replacement. IIRC, it was a piece of a carb linkage off of something. Not much help I know....but he did have them on the shelf. You are covered, but maybe someone else needing them can get lucky at NAPA too.
    DP
    Man invented the slowest form of transportation - the sailboat, Then decided to race them.
    Thats a hell of a big ball stud for a carb.
  1. Wheel Studs
    By tdmuskie in forum Stock Tech
    Last Post: April 15th, 2018, 08:02 PM
  2. barrman : Ball Hitch
    By Barrman in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:26 AM
  3. Gilbert, PA Red Ball Event
    Last Post: September 5th, 2008, 12:32 AM
  4. Replace with bolts and remove studs???
    By viperman in forum Modified Tech
    Last Post: February 5th, 2008, 07:49 PM
  5. Hub flange studs
    By FSJGuy in forum Open Discussion
    Last Post: February 12th, 2007, 04:19 PM
