The detroit "lunch box" locker for the rear is about as stupid simple of an install as you can get. There is also a Lock Right "lunch box" for the front that installs similar to the detroit, slightly more time comsuming than the rear simply because pulling the axle shafts takes longer...but the actual locker install is a breeze.
Tools and shop ready, you should be able to do the rear in 3 hours or less, no longer than 4 hours for the front including including a couple potty breaks.
If you want more detail of the installs, just ask.
Snow on pavement could be a serious issue, off road, they rock.
