I replaced almost all the brake lines on my truck as well as both rear wheel cylinders. Shoes and drums where in good shape. I was re-bleeding the system yesterday because the brakes where still pretty soft. Re-adjusted each brake as well using the star adjuster. My neighbor a heavy equipment mechanic was assisting. My problem is that my driver side rear brakes locks up before the 3 other brakes. It was doing this a bit even before I re-bled the lines.
We played with the adjusters for a while, but could not fix the problem. Neighbor feels it is a pressure problem, uneven brake fluid pressure to the two rear wheels. The brakes seem so simple, could this be the problem?
One thing very odd, on my brake line from the rear passenger side to the T block on the axel, the metal brake line goes into a rubber type line which loops and then goes into the T fitting. This looks odd and does not show in the parts manual. I also looked on my m725 and this line run directly from the wheel cyl into the T block? Is my m715 odd or should this rubber line be there? That line is also the only one I did not replace because it did not come with the replacement set. Any suggestions on problem resolution is welcome.
Brakes feel great except the one wheel keeps locking up.
