While attepting to free Charlie from a deep crevasse( I had to climb up out of Charlie with a springover and 38's!!!)I shifted to reverse and dumped the clutch when KABOOM!!! all movement stopped and a loud grinding could be heard from transfer area. upon dissassembly i discovered that the sleeve between the chev 4spd output shaft and the 205 transfer input shaft had exploded in the adapter. Is this commen and is this part readily available?
