Results 1 to 7 of 7
Thread: Glueing Rubber to Rubber
    Springdale, Arkansas
    Default Glueing Rubber to Rubber
    I've got some 1/8" thick rolls of rubber that I would like to stack and bond together. What, in your opinion would be the best cement to use? Of course I need a permanent bond. Thanks, T
    Pliobond. Need a link?
    Lone Pine, CA
    I used to use generic contact cement, available at Home Depot in quart cans. I'm not sure if it was Dap brand or what it was but it worked. We also used some expensive 3M specialty contact cement with the same results. This was for 1/8" rubber sheets used as a pressure skirt for FDA and explosive application assembly line machinery.
    Chris
    Barge, Seal all, Dap, Pilobond...they all do about the same.
    Zone holster maker
    Cool, thanks. I remember the thread about Pliobond being the shizzle so I think I'll pick up a bottle today and give it a try.
    I can't find suitable replacements for the canvas bumpers over the winshield wipers so I thought I'd use two layers of laminated 1/8th rubber strips.
    Did you try VPW?
    Thy had a very large roll of it last I was there...I asked if they had any and they pulled out this big roll and cut me off 2 pieces...they caled it a canvas welt.
    Linden, Michigan
    Loctite Black works as well. I've used that on automotive seals.
  1. Rubber Booty
    By sf38a1 in forum Stock Tech
    Last Post: March 4th, 2008, 11:58 AM
  2. Rubber spline for vent window.
    By boghog in forum Stock Tech
    Last Post: September 8th, 2007, 07:32 PM
  3. Rubber Weather Stripping source
    By Gregg Irvin in forum Open Discussion
    Last Post: March 5th, 2007, 08:07 AM
  4. Rubber Tailtgate Bumpers
    By 65CJ5 in forum Stock Tech Archives
    Last Post: February 25th, 2004, 08:05 PM
