Allllrighty then, Got Frankenstein's wiring harness installed to the point of hooking up the parking, running and turn signal/stop lights. I think I have figured out which ones I want to do what. BUT I have converted to 12v of course. The lights I'm using are Gubment issue M35 teardrop style for the rear and the newer more modern looking large orange lenses for the front. They both have the black out lights in the bottoms but these wont be used soooo, anyway I need new bulbs for this mod.
I went down to wally world and my local autoparts store looking for (okay, now go with me here) the large dual element, single contact point on the bottom with the locating/locking pins equal height (low). Same goes for the smaller diameter bulb for the top application with the same base as described above. NO CANNY FIND! Are these bulbs actually out there or what?
The bulbs that are in them are the 24v, these wont work on a 12v system will they? Probably wouldn't illuminate brightly enough if even at all?
I was thinking that I may be able to use a dremmel tool and cut a higher notch in the bulb holder to accomodate the style bulbs I can find but is that really practicle?
Can someone who has done this before please post up and share the solution?Thanks in advance, Tracy
