Results 1 to 4 of 4
Thread: Headlight switch and turn conversion
    Dec 2008
    ST LOUIS,MO
    Default Headlight switch and turn conversion
    Has anyone who has converted to 12 volts used the original headlight and turn signal switches? Wanting to know if anyone documented the pin letters on the switches to wire in "civilian" style wiring? Thanks for any help. Or even a light switch number to letter conversion?
    Stock switches work just fine at 12v.
    I believe the pin diagram you want is in the on-line manuals at the top of the page.
    भगवान तुम्हें प्यार करता है
    Dec 2008
    ST LOUIS,MO
    I should have looked a little closer. Thanks again, just a little overwhelmed trying to get my truck on the road before it gets too nice outside.
    The solid state turn signal switch will work fine on 12 volts...the earlier Distribution box setup wont unless you convert it internally per Amphi's procedure, documented in the Online Maintenance Manuals page OR convert to solid state signals per my conversion page in the Online Maintenance Manuals.
    The 3 lever switch doesnt care...it will work on 12 volts fine.
  1. Replies: 10
    Last Post: November 2nd, 2008, 08:40 PM
  2. Headlight switch breaker?
    By the1968jeepthing in forum Stock Tech
    Last Post: November 3rd, 2007, 04:13 PM
  3. Steering column and headlight switch
    Last Post: October 28th, 2007, 10:55 PM
  4. multifunction headlight switch
    Last Post: June 13th, 2007, 09:46 PM
  5. Headlight and Turn Signals LED
    By spr-m715 in forum Modified Tech
    Last Post: January 15th, 2007, 11:00 AM
