Results 1 to 10 of 10
Thread: fisherman : Posi or Power Lock?
    Washington State
    Default fisherman : Posi or Power Lock?
    Posi or Power Lock?
    Post by fisherman on Aug 27, 2006, 1:18pm
    Snapped a shot of my carrier, seems there was some debate over what this is. Anyone know for sure? Post up, Power lock or posi and what brand? Thanks Everyonehanks Everyone
    Default bigwheelbob :
    Re: Posi or Power Lock?
    Post by bigwheelbob on Aug 27, 2006, 1:43pm
    Looks like a dana powr-lok
    Default thetroublemaster :
    Post by thetroublemaster on Aug 27, 2006, 2:18pm
    Thats not a Powr-Loc. I have great pic's of a D60 one at work. I won't be back there till thurs.
    A Powr-Loc has a very cylindrical case. Meaning there are no casting valleys for the case bolts. A Powr-loc case bolts bolt in through the end not almost half way into the case as seen above.
    Another tell tale sign is a PL has "V" shaped ends on the spidergear shafts. They sit in a case hardened "V" shaped valley you can't miss from others. Thats is what makes the PL so cool, the way the tire spins and ramps (clamps)the spidergear and clutch set tighter offering more traction. The heat treating has always been a very obvious blue color surrounding the spider gear shaft. There is a BUNDLE of information on PL's at vernco.com
    Anyway, thats not a powr-loc...
    Post by bigwheelbob on Aug 27, 2006, 5:34pm
    I am sorry, the early dana 70's were 2 piece cases I believe. I got all excited for a moment.
    Default robertcowan :
    Post by robertcowan on Aug 27, 2006, 11:03pm
    TODD ITS A STOCK DANA 70 OPEN CARRIER. IF ITS POSI IT HAS A DETROIT LOCKER IN IT. I GOT A BUNCH OF POWER LOCKS AND LOCKERS, I KNOW EM GOOD.
    BOB
    Washington State
    Default fisherman :
    Post by fisherman on Aug 27, 2006, 11:09pm
    So far 3 different opinions?
    Port Orchard, Wash.
    Default binfordm715 :
    Post by binfordm715 on Aug 27, 2006, 11:12pm
    I have the same junk in my rear end. I had the back end jacked up and when I turned one wheel, the other turned the opposite direction. That's open behavior, is it not?
    Default jeepistdougiowa :
    Post by jeepistdougiowa on Aug 27, 2006, 11:20pm
    Bob is right, it's a stock open unit.
    Always possible someone installed a detroit nospin "lunch box" inside it...hard to tell by looking at it.
    Stock, with the tire off the ground, spin one tire one direction and the other will spin the opposite direction. With a no spin they will spin the same direction.
    Regardless, the picture is a stock carrier.
    Post by jeepistdougiowa on Aug 27, 2006, 11:21pm
    Yes Tim, that's typical of a open dif.
    Post by robertcowan on Aug 28, 2006, 12:06am
    IF YOU GOT A DETROIT LOCKER IN IT YOU,LL KNOW IT WHEN YOU DRIVE IT I PROMISS. ITS A BEAST ESPECIALLY ON WET ROADS IN CORNERS. ALSO ITS A KILLER ON ROAD WITH TIRE WEAR. WHEN MINE RATCHETS IT WILL JERK THE WHOLE TRUCK. NEED ONE ? I GOT BOTH SETUPS IN STOCK.
    BOB
  1. robertcowan : 14 BOLT POSI ????????
    Last Post: November 11th, 2009, 01:31 AM
  2. Pintle lock pin?
    By fishtail in forum Stock Tech
    Last Post: October 24th, 2009, 08:37 PM
  3. Open diff or Power lock?
    By fisherman in forum Open Discussion
    Last Post: October 20th, 2008, 10:59 PM
  4. Lock the fuel cap
    Last Post: September 4th, 2008, 12:47 PM
  5. Power Brake Lock up!!
    By VaM715 in forum Modified Tech Archives
    Last Post: March 24th, 2004, 08:52 AM
