In the old days "armored" bake lines where just brake tube with a steel wire wrapped around the line like a spring to "protect" it. The problem with that is the spring would hold onto mud and dirt and corrode the brake line.
I want to use an "armored" brake line on my project truck, but don't want the spring wrapped line. Is there an off the shelf armored, off road brake line tubing that is available? I was thinking like a braded steel line, but I don't want a flexible line where I should be running a hard line. Or am I just over thinking things and just used standard brake line and not worry about it?
Thoughts?
