  #1
Old June 1st, 2020, 02:35 PM
stellmach stellmach is offline
Civilian
stellmach is a Soldier
Default get it to run.
Hey guys I've been working on the stock 230 tring to make it run, I've set the dwell, gapped the plugs, dielectric the connections, cleaned flue lines and filters. Starts on the first hit, sputters for a couple minutes and dies, cant give and throttle during sputtering. Also noticed gas leaking from the bottom butterfly housing... possible problem??
Thanks
  #2
Old June 1st, 2020, 03:41 PM
gonz's Avatar
gonz gonz is offline
Administrator
gonz has disabled reputation
Sounds like your carb needs a good cleaning and the float is sticking open.
__________________
Come and take it
  #3
Old June 1st, 2020, 05:14 PM
m38inmaine's Avatar
m38inmaine m38inmaine is offline
Private
m38inmaine is a Soldier
Agree, a carb clean/rebuild, cheap and simple.
  #4
Old June 2nd, 2020, 06:48 AM
Civilian
Thanks, that's where I was headed too. Took it off last night and the throat and choak flap looked like the inside of a chimney, found one soggy and half split gasket under the valve body. Was wondering, when I got this it had a fuel pump with 30 psi@80 gallon flow there was a regulator but who knows. Question though is could the fuel pressure have damaged the carb?
  #5
Old June 2nd, 2020, 07:31 AM
Don Cavey's Avatar
Staff Sergeant
Don Cavey is a Soldier
I am no expert but I think that 30 PSI is way too high for this carburetor. Isn't it usually less than 10 PSI?
  #6
Old June 2nd, 2020, 07:38 AM
Don Cavey's Avatar
Staff Sergeant
I just checked the online manual (Link at the top of this page, TM 9-2320-244-34 Direct Support and General Support Maintenance Manual) and here is what it says: "Pressure should be 3-1/2 to 5-1/2 psi at 600 rpm"
  #7
Old June 2nd, 2020, 07:53 AM
gonz's Avatar
Administrator
30 psi is almost getting to fuel injection levels. Probably 3 times too high. Can you turn that fuel pump off? I've seen a lot of four wheelers that used both the stock fuel pump and an auxiliary pump to help out on really steep inclines. Quite a few of my friends with old CJs would run them but I don't think any of them were close to that kind of pressure.
__________________
Come and take it
  #8
Old June 2nd, 2020, 11:47 AM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
Fuel pressure should be 4-6 psi. Any more than that will flood the carb. You could regulate it down.
If you still have the stock fuel pump it can be rebuilt. http://www.then-now-auto.com
  #9
Old June 2nd, 2020, 07:12 PM
glenn glenn is offline
Sergeant
glenn is a Soldier
Anything over 7 psi is too high for any carb. They used to make fuel pressure regulators you could put on between the carb and fuel pump if you had an electric fuel pump that had too high of pressure.
  #10
Old June 5th, 2020, 04:43 AM
brute4c's Avatar
brute4c brute4c is offline
Grand Poobah
brute4c is a Soldier
Correct....7 psi is the max carbs take before you start blowing the needle off the seat.
__________________
Tags
carburator, idle, sputter, tune up
1998 - 2020
Copyright 1998-2020
