Results 1 to 10 of 20
Thread: Pistons for a 230 Tornado?
    The cesspool of WA state
    You listed everything and more. I instantly thought of Kanter. Well never mind there... So I had a set of pistons made for an older 4 cyl mercruiser boat motor. The engine builder said they were not much more than over the counter pistons. He had trouble finding only 4 pistons and no parts places would break up a set of 8. So he had them made out of California.
    M and S engine in Ponderay ID. Greg is his name. He has built a couple engines for me and some other machine work. He is slow but meticulous. The engines he did for me all run like a sewing machine.
    You are left with sleeving and STD bore pistons, waiting for ebay to have oversize pistons pop up, or like some would suggest, repower....
    I would keep looking and try to be patient. You never know.
    Wow, That's discouraging
    I thought that Willys America or Kanter would at least have some.
    They were my "go to" source of quality parts, when I was rebuilding my Tornado 230.
    I'm planning on exhausting all reasonable options before resorting to an engine swap. For better or worse, the difficulty of getting parts is strengthening my resolve to get this thing running and back on the road simply because it seems like it won't be getting any easier to do it.
    Kanter made it sound like they had a production run of pistons made in China and were simply at the end of their stock, but made no indication that they would be ordering more. But they're at least set up for it.
    For the purpose and condition of my truck, I won't likely be ordering custom pistons of any kind, if anything I'd sleeve and re-bore it back to standard, but even that's going to cost me $1k to do. Before I go that far, I'd probably just hone the block I have, take down the ring ridge, throw some new rings in my standard pistons and accept that I'm going to have some blow-by.
    If nothing else, hopefully this will provide some info for others moving forward and running into the same issues I have.
    At this point if it were mine, I would do a minimal hone and rering it. Then run a high zinc oil like Valvoline VR-1. All older engines should have high zinc oil. The claims of new oils being backwards compatible is BS. If it were true then I would not be continually finding flat cams in the motors I am opening up. And in trying to keep up a questionable reputation, I must make a statement on fram filters and how you would be better off tossing a handful of sand in your motor.
    Jun 2014
    Eastern Maine
    Does not say what size but does say newly made.
    http://www.performancenowdirect.com/...waAtBLEALw_wcB
    I would also message this ebay seller, they have a lot of parts for 230.
    https://www.ebay.com/itm/NOS-JEEP-KA...YAAOSwl9BWHPoS
    Quote Originally Posted by m38inmaine View Post
    Good call on both! I've messaged a couple other sellers, but I missed that one.
    And I'll give the other place a call too, and report back. Thanks a ton!
    Just to keep this updated for future reference....
    The seller "nos4jeeps" on eBay replied to my first email about 2 months ago, but has not responded to any other attempt to contact him. I found and sent him a message on Instagram- no dice. I found his company page on FB which had an actual email address, so I sent on there, no reply.
    I've had similar trouble from Performance Now Direct. They never answer the phone, and the emails I've sent go about a week before reply. They did confirm that whomever they were buying pistons from is no longer producing them, so whatever they have in stock is the end of it. But then they can't confirm or deny what they have in stock. It's quite confusing.
    All that to say, no progress.
