Oil pump leak
So if I'm correct, the oil pump sits under the distributor. That is where my leak is coming from. It's definitely a class 2 leak with a small puddle and oil drops forming (for those of you who have spent time in an actual motor pool!). I assume there is a gasket on the flat plate where the bottom plate bolts on.
Are the civvy model 230's the same in terms of oil pumps? Can I go to a parts store and buy the gasket or just use RTV? I have a complete gasket kit for the 230 but don't want to tear into yet. Thanks
1-1AD 4-17 INF B Co OEF 12-13
