Old December 18th, 2020, 12:59 PM
teking teking is offline
Corporal
teking is a Soldier
Default Rock Sliders
Help me out here guys ..... Is the 1963-1973 J-Truck Shortbed basically the same frame as our M715?? See picture .... I'd like to get a set of these but obviously M715 isnt an option. Will ANY of these options work? Since they are bolt on they are worried about fitment. But I will cut off the mounting plates and just weld them to the frame.
Old December 18th, 2020, 02:34 PM
kwai's Avatar
kwai kwai is offline
Sergeant
kwai is a Soldier
I don't think so. Why not just get a custom set built at a reputable offroad shop.
Old December 18th, 2020, 02:51 PM
Corporal
teking is a Soldier
Yeah..... I was assuming that if I had a custom set built that would be extremely expensive trying to cut some corners. Looks like I'll have to do that thanks for the response.
Old December 21st, 2020, 06:33 AM
Nailhead's Avatar
Nailhead Nailhead is offline
Corporal
Nailhead is a Soldier
Quote:
If you have welding capability, why not build your own? Or buy the ones pictured and modify them?
Old December 21st, 2020, 02:15 PM
Private 1st Class
jhartings is a Soldier
Sounds like a good opportunity to buy a welding machine!
Lincoln MP210 is a great welder.. bit pricey but was worth it to me.
  #6
Old January 1st, 2021, 08:21 PM
Direwolf82's Avatar
Direwolf82 Direwolf82 is offline
New Recruit
Direwolf82 is a Soldier
I second that, good excuse to get a welder!
Sliders are super easy for our trucks, mine came with some 3"pipe sliders/steps and I haven't mangled them yet. Probably cost around 100 in material for a 21' stick. Don't ask me why they come in that random length.
Unless your looking for something fancy with a bunch of shape all you really need is some steel, a stick welding setup and a grinder.
Stick welding may not be the prettiest or easiest but I like to weld outside in the open air and gas shielding doesn't really like that situation.
If I was going to make myself another set I'd probably go for some 3" 1/4 wall square stock. Strong and easy to work, curves can be a pain welding sometimes, especially if your still learning.
Edit: check out my profile pic. Not the prettiest things in the world but they are there doing the job.
  #7
Old January 5th, 2021, 11:39 AM
Corporal
teking is a Soldier
Unfortunately pic is too small to see. Can you post a bigger pic of your sliders? Also did you weld them to the frame or bolt them?
1998 - 2021
Copyright 1998-2021
