Thread: braden pto winch
    problem with my winch....the freewheel handle is jammed... it will not come loose to freewheel the winch. i've tried tapping it with a mallet and still no go...
    Atlanta, GA
    I had the same problem with mine when I first got my truck. It was all gumped up inside from lack of use. My father took it apart ,since I was only 8 years old at the time, and cleaned and greased it, and it has worked great for the past 22 years. Has yours always been jammed or is it a new problem? I have a manual for the winch that shows all the parts and assembly. I could send you a copy if you like.
    Jeremy
    Boy Jeremy...I would like a copy of that manual for the site...I'll PM you some info...
    yeah as far as i know it has always been jammed....i'd love a copy of that manual.
    thank you
    scott
    If it's anything like the deuce winch it will have kind of a simple throw out fork design like in a clutch. I had a deuce winch that was frozen up like that.
    Big Blocks RULE!
    Atlanta, GA
    I'll look for the winch manual, it is boxed up in the basement from our last move, so it may take me a couple of days to locate it. As soon as I get my hands on it, I'll send a copy of it to you.
    Jer
  1. braden winch rebuild
    By jaymzm715 in forum Stock Tech
    Last Post: January 15th, 2009, 12:15 PM
  2. Braden winch question
    By Pineyguy in forum Open Discussion
    Last Post: December 5th, 2008, 04:02 PM
  3. Pros & Cons of the Stock Braden winch?
    By dukhunter785 in forum Open Discussion
    Last Post: December 19th, 2007, 11:13 PM
  4. braden winch
    By maccj715 in forum Open Discussion
    Last Post: May 25th, 2007, 08:10 AM
  5. Roller Fairlead for Braden winch
    By room4ten in forum Open Discussion
    Last Post: February 2nd, 2007, 08:38 PM
