Results 1 to 10 of 11
Thread: Tire size question
    Default Tire size question
    Hello All,
    Wanted to know if 325/85 16's will fit a stock truck on stock split RING rims?
    Thanks,
    68' LS TT 6.0 /4L85e /AMG 242
    not sure of the actual dimensions of the tire u're referring to but an 11.00x16 is about all that fits comfortably. i believe they are 38 tall & about 9 wide.
    Jul 2011
    North Pole Alaska
    I have a set of the michelin XML 325/85/16s on my truck with the original rims. The only thing I have found is they will rub if you try to turn to sharply but other than that I havent noticed any problems. The one thing I had trouble with was getting someone to mount them. I found a local guy that did them and havent had any problems.
    here are the tires mounted
    Here they are on the truck
    They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety
    Thanks for the info. I was wondering the same thing. 11.00x16 are getting extremely difficult to find these seem a little more common.
    M715
    M725
    48 Willys PU
    49 Willys Jeepster
    59 Willys Wagon
    76 Cherokee Chief
    97 Jeep GC
    02 Jeep TJ
    It's a Jeep Thing!
    Jul 2011
    North Pole Alaska
    No worries it actually seem to ride smoother with these big tires and dang does it look good
    Thank you I was contemplating buying a set, can you tell me where you got yours and how much you paid for them?
    It seems like tires for these Jeeps are taboo, I really want to run a set of MTRs, but I don't think I can.
    Recommended rim width by design from Michelin for the XML 325/85/16 is a 9" rim.
    Doesn't mean that you can't install them on narrower rims... simply means that the tires were designed for a 9" rim.
    Jul 2011
    North Pole Alaska
    Quote Originally Posted by RAMairGTO72 View Post
    I purchased them from Wartires.com they are based out of FL and I got a deal on them. If I remember correctly it was around 1100 shipped.
    And I was told the same thing that they should be on a 9 inch or wider rim but the do fine so far on the stock rims with a good high quaility tube in them
    i bought my 11.00X16's brand new thru ryan at bj's offroad. they came out of wash. & supposedly he can get more.
    Jul 2011
    North Pole Alaska
    Lol where were you when I was looking for those oh well i like these just as well
