Ok , I see...
Yes, You would get 12 volts. Either Positive or Negative , depending on how Its measured.
Depending on how you look at it / measure it, it would be 12 "negative" volts, using the POS lead to be the 12 volt battery, and the NEG lead to be the POS of the 24 volt bank.
( Neg - 12 volts )
Switch around, with the Negative being the 12 volt battery, and the Positive to be the 24 volt bank... and then you get a Positive 12 volts.
I know that "most "12 volt appliances do not "care" which way the voltage runs....
but this result is opposite of what I would have expected...,
and any appliance that "needs" the positive lead to be on one leg specifically, and the negative on the other leg....
could easily be reversed.
Will not reversing the voltage cause induction of corrosion ?
It seems, the positive charge would be flowing through the frame now, using the 12 volt pos post for the "positive" of the 12 volt circuit...
Which really is running the power backwards... being Negative 12 volts.
Would this positive charge in the frame not attract / cause corrosion ?
Ions attracting other ions with a reversed polarity?
opposite of how it normally lives?
This is where I get confused...
its not just the flow of the electricity from Pos to Neg,
but
when things get crossed like this... (flow and Pos or negative charges in surfaces )
are there not other issues that come about that are not "electrical" per say, but "side effects"...
Like corrosion ?
Sacrificial erosion of components not "designed " to become sacrificial?
See, I jumped to ionic attraction and probably induction as well...
as a side effect to not isolating things.
