Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: New wiring harness
  1. #11
    Barrman, which wire did you drop from the 4 wire ignition switch to use the flame assist? I am going the M35 route for the M715 wiring.
    I am a bit bummed that the NOS m715 wiring was not such as advertised. But, I game for a challenge. It looks like I will unwrap the loom and reposition some of the wires since some items alternator etc are in different locations. I have a SBC 12 & volt conversion
  2. #12
    UGH. We did that conversion on the M715 for Pistolnut years ago. I did the harness on the M35 gasser 10 years ago. Just this morning I had my students installing the stock wiring harness on the M715 for Sermis. I have been thinking light numbers, not engine related numbers.
    However, I am pretty sure the flame heater wire is what we hooked to the distributor since it is already part of the under hood loom.
    Under the dash I am pretty sure we took the M35A2 starter button wire which is hooked into the 4 wire switch and then connected that to the flame heater wire.
    Again, I am almost halfway through removing all the wires on my M35A2 to put in a new harness but haven't touched it in a few months. I will be very fresh on all the numbers again once it warms up a bit.
    Sorry I am more vague than exact on this. I do remember it was a wire right there at the on/off switch that had no use outside of a M35A2 that I got power from and the flame heater wire was right there on the engine with the oil and temp connectors so I just connected them.
  3. #13
    That's what I did too. I need a steady 12 volt feed to my ballast resistor when the switch was in the on position.
  4. #14
    Dec 2017
    ARKANSAS CITY, ks
    Quote Originally Posted by TXfirefighter View Post
    I am getting to the point it will soon be time to start wiring the old truck. The original harness is in sad shape so I am looking for a replacement.
    I have sent a request in to Painless wiring but have not heard back yet.
    Do you guys have suggestions of where else to look for a replacement harness? OR, where NOT to look?
    I am trying to keep as much of the military switching and lighting as possible.
    Putting a Ford 300 straight 6 in it with a ZF 5 spd behind that and a divorced NP205 so wiring for the drivetrain is not going to be hard.
    I see you are putting a 300 six and ZF-5 speed in. Have finished and yet and how do you like? I'm seriously considering it for mine.
    Sent from my SM-G930P using Tapatalk
  5. #15
    Quote Originally Posted by 78FordF150 View Post
    Not done yet. Life and work have slowed the project and, we just built a 40 X 40 shop. So I've been moving from the rental location to the 1 we own.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  6. #16
    Dec 2017
    ARKANSAS CITY, ks
    Keep us posted when you get it finished.
  7. #17
    See my build thread in the General discussion area...
    Now that the shop is finished and I got moved in, I've been able to work on it more than I have in over a year!!!
  8. #18
    I just used the M35A2 wiring diagram to make it all work. I used Wire 74A and 74 for the starter foot switch and made a jumper where is should hook into the fuel pressure switch. I ran my electric fan, lighter, and ballast resistor off the #27 junction and others that had power when the ignition switch was on. It just took some consternation of looking at the diagram.
  9. #19
    I'm going to use the Power Plus 20 wiring harness from American Autowire.
    It's got what is needed and I can add wires for the Blackout lights. It should be easy to adapt to the military 3 lever headlight switch and 715 turn signal switch so, wish me luck!
  10. #20
    My intention as well
