Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Dana 60 sua steering questions
    New Haven, CT
    Quote Originally Posted by 67smith View Post
    I would use an outer round and an inner square u-bolt - use a plate under the spring- something just don't look right with that set up.
    That's what I did, but his setup will work too, just a bit more complicated.
    Sep 2014
    Southern New Hampshire
    Ok, staring at it a little longer the two things that concern me are: no threads showing on inner u-bolts(probably caused not torqued?), and the outer portion is weak-because of the upper and lower welds-the most weak point of a weld is at the edge of a weld-I think if you add another brace to the outside edge it would be a better design. And improve general strength-
    Oct 2016
    Dracut, Massachusetts
    Thanks, for the feedback. Yeah like you said nothing is torqued down yet, but i doubt I will gain enough to get a washer and fully thread a nut on there once its at its final torque. I plan on machining some material out of there to make up the difference. Also, the piece on the axle tube will be welded on the tube. This was just a mock-up to see if everything was going to fit. Thanks again.
    I plan on just doing highsteer and crossover on my Ford SUA setup.
    Hopefully I can get the tie rod/drag link under the frame rail and still have suspension clearance. (Even though its only like 3" of travel before OEM bumpstops)
  5. #15
    Oct 2016
    This is what I came up with. Thanks for the idea Mikel
  6. #16
    Eightyduece....Given your pinion angle... do you think high steer arms (like I'm planning on doing) and linkage sitting atop those arms would clear the bottom of the frame rail?
  7. #17
    Oct 2016
    Quote Originally Posted by venominjected View Post
    Look like you'll have 3 to 4 inches of clearance
  8. #18
    Quote Originally Posted by eightydeuce View Post
    Pretty much all the travel before OEM bumpstops anyhow. I'm hopefully going to be able to give it a go and find out.
    Thanks for giving me a heads up and allowing to at least continue down that path.
  9. #19
    New Haven, CT
    Looks good!
    One thing I would have done different is the bottom of the passenger side. Right now you have two u-bolts that transmit the load to the springs, in two localized areas. I would have put a plate there to spread the load and minimize the chances of fracturing a leaf. But I may be overthinking it. Keep up the good work.
