I went with electrical gauges and had some questions concerning sending unit placement.
I have installed the Oil Press. unit over the Oil filter.
Where should I install Temp unit ? I do have a port on the Intake manifold, but will probably use it for a Heater hose. I do see some plugs(looks like 1/4 or 3/8 pipe plugs) towards the bottom of the Block but do not know if they are for Water or oil.
2nd Question is, Is a weld in Bunge better for Trans. temp. sending unit or is the in line manifold fine ?
