Originally Posted by
Wintermute
Okay, I know I haven't been on here in forever and a day...but I'm finally getting back to my m715. Still have an issue where the oil pressure once warmed up drops to zero and then starts running really rough.
On start and idle (until it really warms up, the old 230 runs at 30psi...revved it jumps to 60+). Once it runs for a while and warms up fully, it will start dropping a bit at a time until it hits zero pressure...when it drops to about 20, the engine starts to run pretty rough (shaking, uneven idle, and some knocking). When it first starts up it sounds and runs like a a brand new engine. Once the pressure starts dropping it's a sure path to zero. Running brand new 10w-30 in it with a nos oil pump.
Any ideas here? I wondered if the block has a crack, or if the timing chain cover gasket is shot and allowing oil to blow out of the through passage once warm. Anyone had this problem before and figured out what it was?
Thanks in advance,
--Wintermute
