Results 1 to 10 of 13
Thread: All Time Four-Wheel Drive?
    Default All Time Four-Wheel Drive?
    So, I used the search function for an hour and could not find an answer to my question...
    I met with my builder the other day and he showed me my NV4500 transmission bolted to some sort of old overdrive unit. He explained that once it was installed I would have a high, neutral, and low gears.
    I didn't realize what he was saying until later. I think what he was saying is that my truck will only have 4WD. I know he/we have been searching for an easy solution to the stock low-gearing. But, I don't know if this is OK.
    Will it be OK for my truck to be 4WD all the time? I would worry about fuel economy, but on some level I think the range of gears will help me keep my RPMs down.
    What do you think?
    Feb 2007
    Bloomfield CT
    That sounds like a regular 2 speed transfer case.....Unless there is still a T-case to go behind that? Did the O/D unit have 2 outputs for driveshafts on it?
    Is that real money?
    I saw my guy again today. I asked him: "So, it's a two speed transfer case?" He told me "Yeah, it's the one everyone wants, it's worth a lot of money."
    I took some pictures while I was there.
    So, does this mean I am 4-wheeling all the time? Is that OK?
    In the first picture, see the little round white/silver tag with the red ring? That should tell you the model of the transfer case. It should be easy to look up on the net.
    1967 M725
    M101A1
    CW3 Ret
    W8BWD General Class
    That looks like a passenger side drop NP208 or 241. There is a number inside the red data plate. Get that number. Chain drive, aluminum case. That is not a full time all wheel drive unit unless I am missing something.
    Why do you want all wheel drive on the street? It will make a lot of drag and wear out stuff faster than a normal 4 wheel drive when you want it on soft surfaces.
    By the way, most everybody seems to want NP205 cases because they are cast iron, gear drive, PTO drive port and pretty much bullet proof. The aluminum chain drive units are more prone to cracking and have shift fork bushings that wear out and need to be torn down completely to fix.
    Just asking. It is your truck and do as you wish.
    Default 2-Speed Transfer Case
    Next time I am there I will get the number from the data plate. My guy said this is the solution to my gearing. (Gears too low to drive on the highway.)
    I would rather have a NP205, but then I have to swap axles, or gears...
    But if I've got it right, I will be in two wheel drive (with the transfer case
    in neutral) and then either 4-high, or 4-low. So, I won't be 4-wheel drive all the time. But this will only help me if I put int in 4-high when I want to cruise down the highway.
    I wont' be driving on the highway much, and when I do, I won't be making any sharp turns. So, it seems like an OK plan to me. He likes it because its married, instead of divorced. If I want him to change it, I have to have to be able to tell him why.
    New Haven, CT
    Quote Originally Posted by DeanJohnson View Post
    Nothing wrong with a NP241. Barrman is right about the NP205 being more robust, but the vast majority of NP241s go to the junkyard being operational. I wouldn't sweat it. Besides, you get a better low range.
    Maybe I am just being dense tonight or something. But things just aren't adding up for me. I see the red NV4500, I see the aluminum housing at the back for 5th gear which is also the cross member mount and the t-case mount. Then I see a transfer case with a long tail slip yoke. Where is the other drive?
    A NP208 or what I think you have, NP241 has 4 selections: 2 hi which just drives the rear axle, 4 hi which drives both axles at the same speed as the input from the transmission, neutral which lets nothing be driven by the engine and 4 low which drives both front and rear drive shafts at 2.?? times less than normal. There are no other options that I can figure out.
    Normal driving will be in 2 hi and it will behave just like any other rear wheel drive vehicle.
    I'm not trying to pick on you. I am just trying to figure out what is unique about this set up.
    New Haven, CT
    I think the confusion came from the two speed transfer case. I too expected an overdrive like a Ranger or Brownie.
    that configuration will improve your highway speed in 5th gear. In 2 hi (or 4 hi) the gear ratio through the tcase is still 1:1. The overdrive in the nv4500 will help on the highway speeds with a ratio 0f 0.73:1. 4th gear is a 1:1 ratio.
