Results 1 to 3 of 3
Thread: 12 Volt Starter
    Default 12 Volt Starter
    I converted my M715 to 12V, but I'm still using the 24V starter. It has become impossible to start when the engine is warm. Does anyone out there know of a readily-available 12V starter? I don't think that the stock 24V starter is spinning fast enough with just 12V running through it.
    Thanks, Brad
    There are 2 choices here...
    1. Tour the junkyards and ebay and look for a 63-65 civilian Jeep with a 230 engine...they used a 12 volt starter that interchanges wth the mil 24v one just fine...hard to find but out there.
    2. Some starter/alternator rebuilders can rewind the starter to operate in 12 volts, check out those in your neighborhood...something the size of Albany should have a good rebuilder in the area or know of one that can do that.
    In the short run, you could just wire a second battery in via a solenoid just to turn the starter, giving you 24 volts. This was a trick that we used to do all the time on the 6 volt WWII Brit armored cars I used to restore. Worked like a charm. We'd stick the extra battery on a trickle charger when the carriers were going to sit for a while, as it was not attached to the generator.
    Zach
  1. 12 Volt Starter Questions
    Last Post: September 21st, 2014, 06:08 AM
  2. brute4c : 24 volt Alternator & Starter rebuilder...
    By brute4c in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 04:06 AM
  3. Starter
    By Rakes67 in forum Open Discussion
    Last Post: November 18th, 2008, 10:48 AM
  4. 12 volt tach, 24 volt system
    By vacca rabite in forum Modified Tech
    Last Post: May 19th, 2008, 03:12 PM
  5. where to buy a stock 24 volt starter
    By rocky4by in forum Stock Tech
    Last Post: January 8th, 2008, 01:18 PM
