Results 1 to 3 of 3
Thread: Hub nut removal...more insight needed
    Default Hub nut removal...more insight needed
    Well, I have the rear axle out and now I am trying to remove the hub nut. I bought the 2 1/2" socket for it....but I think it is too big.
    Also there seems to be "key ways" or "tabs" for lack or a better term, that is keeping the socket from going on very far.
    Obviously I am missing something again.....
    Thanks,
    Jeff
    there are two nuts in there an between them is a lock its a flat piece w tabs around it after inside nut is in you place the lock in an install the outer nut over it then bend over one or two of those tabs over the flat of the outer nut, you must bend those tabs back out flat agian to get the outer nut off usually a flat chisel is good to do it or a strong flat screwdriver just get under the tab an bend it back then when u reassemble u will need to bend the tab back to hold the outer nut.
    68 M-715 MVPA #2710
    Thanks George, I will go give that a look/try.
    I love this forum and all the great help you guys give!!
    Thanks for the super fast reply!!
    Jeff
  1. jed : M715 Cab Removal
    Last Post: November 11th, 2009, 05:09 AM
  2. cam removal
    By kevbo in forum Stock Tech
    Last Post: September 14th, 2009, 07:12 PM
  3. Bed removal, pic's
    Last Post: January 12th, 2009, 11:53 AM
  4. Paint Removal
    By ffdemoss in forum Modified Tech
    Last Post: February 20th, 2008, 05:51 PM
  5. metal top removal
    By truck6driver in forum Open Discussion
    Last Post: January 19th, 2007, 01:18 PM
