Page 40 of 54 FirstFirst ... 303132333435363738394041424344454647484950 ... LastLast
Results 391 to 400 of 535
Thread: The longest build thread ever, at least it seems like it!
  1. #391
    The cesspool of WA state
    Quote Originally Posted by gonz View Post
    Looks super sharp like always!!
    All done with your help too. Many thanks to you and Glenn for helping me along. Now if I could just get it done.
    Liz, covid, murdered 10/19/21
  2. #392
    Finally getting some shop time in. I usually have lots of time in the winter to do this stuff. I have trying to build an interior kit for a 66 wagoneer based in Utah. And I am kind of held up so I spent some time sanding the fender skirts to get them painted. I need warmer weather for all of it. I hit 31 below zero and it had been below zero or right at it for about two weeks now. It is warming up some. This is a wagoneer fender skirt with a M715 tail piece welded to it. The original M715 one was to rusty and I had this one handy. The M715 tail piece is different than the civi one so I switched them. I spent a whole day sanding this. It had more green paint runs than ever. Crazy bad work. Now I am treating it with SEM rust converter. Another sand down then seam sealer on the seam on both sides then paint goes on. I hope the remaining body parts clean up quicker than these.
    All the black is rust and it is getting sealed in.
    I hope to have paint on these and a whole bunch of other parts waiting very soon. It is a task to get the shop warm enough despite being fully insulated. This paint likes heat to set it.
  3. #393
    Nov 2009
    Greenwood, Indiana
    Wow, that is some cold weather!
    Do you find that paint is very tough to sand off?
    I am stripping the doors and hood on mine, and it’s taking forever.
    I tried paint stripper. It took the red from the FD off, but only softens the top layer of paint
    Thanks, George
    Joshua 24:15
  4. #394
    Yeah...that is cold!!! We have barely slipped below -10 this winter...
    Stay warm Al...we need you!!
  5. #395
    Yes Flingarrows this is the toughest paint I have ever sanded. No kidding, two days to sand both fender skirts. So why does my new tan paint chip so easily? I have been wondering. And I have you beat on temps Jon. The lowest I have ever seen here was 36 below zero. I was 5 degrees shy this time. It is hard to heat the home with that. I am not looking forward to my power bill. The furnace kept coming on despite a hot hard running woodstove.
    It warmed up to 32 today and rain. It was raining at 19 degrees two days ago. Never seen anything like it. So I watched a superb church service online this morning then decided to go out and work on the skirts. I ended up with a quick sand to smooth the rust sealer and put seam sealer on the seams. I got a wild hair and fired off 4 heaters to warm the shop to paint. I got the plastic booth to 68 and went for it. Glad I did it. The fender skirts look way better than I thought they would. Got a shovel painted, steering column, gas can hold down straps, trans boot ring, headlight rings, rear view mirror, etc. I need to not touch it for a few days now. Anyway some pictures.
    Seam sealer to stop rust. I soaked SEM rust sealer in there just in case.
    And the rest of the parts. I have a few black things left to do yet.
    Getting there.
  6. #396
    Well I got the grill guard painted. It took a full day of straightening with a bearing press and various straight edges to get it looking good again. I had one cracked weld to fix and a few dents to fill. Got that done after another full day of sanding it. I painted it yesterday after running the heat in the shop full bore for hours before spraying. I also painted the inner front radiator support. Another sanding joy there. This paint is really something. I put the steering column together and got it installed. I have steering now. I used civi parts on the steering wheel and I think it looks great. For a modified restomod anyway.
    I punched holes for new neoprene seals.
    Nothing is cleaned up yet. I was just fitting to make sure it all fit. The horn components are missing out of my column.
    Onward
  7. #397
    Nov 2009
    Greenwood, Indiana
    Looking good. That looks like a lot of work to strip the grill guard
    Thanks, George
    Joshua 24:15
  8. #398
    It was. My hands are very sore from sanding. But it looks good. Not perfect but it looks good. It will be a woods rig. It won't take long before those little imperfections will be lost in the fray.
    So I started on the top frame. Jiminy freaking Christmas there are some holes in it. From a hard top I am sure. Maybe three different hard tops. I have roughly 28 rivet holes per side. Nuts ... I am welding them up and cleaning them up for paint. I bet it whistled in the wind on the freeway.
    One side all fixed. I am going to pull all the snaps off for paint. The screws are stuck. I sheared the tip of an impact driver. Crazy the cheap crap from china we have now. I have all new black snaps to put back. And I have two new black tops to pick from. It is going to be sharp as heck. I will probably attempt to make a complete top frame set some day. It does not look to difficult. Anyway..
    More later.
  9. #399
    36 rivet holes in the rear bow alone. Somebody shoot me.
  10. #400
    Nov 2009
    Greenwood, Indiana
    Wow!
    Thanks, George
    Joshua 24:15
