Results 1 to 9 of 9
Thread: Axle wheel bearing seals
    Sep 2008
    Stevens Pointski, Wisconsin
    Default Axle wheel bearing seals
    Are these still good for wheel bearing seals?
    All of the bearing #'s are still good.
    The seals have apparently been superseded.
    These should work...
    Front Seal: p/n 475384
    Rear Seal: p/n 416282
    __________________
    Does AB Linn carry both fronts and rears yet? He only has fronts on ebay lately. VPW lists 'bigger and smaller' ones on their listing, but specifically does not say what they fit.
    Scott
    '67 M715 '67 M725 '69 M726 (x2)
    "it's cheap and you get all you can shove in your pie-hole" --Kozmo 12-10-13
    Jul 2009
    Louisville, KY
    I have only been able to find the fronts at the usual M715 vendors.
    The rear I found at NAPA part number 27601.
    Says NAPA on the box as well as "SKF".
    SKF Elgin, IL 60123, also SKF.com.
    Ken
    Thanks for all the help!
    are there any napa numbers for the fronts?
    Fronts and rears are both available from new sources. I have the boxes with part numbers that I used but I'm working on the road right now so I can't tell you what they are. I can say that I found the part numbers on here, so with some searching and calling around you should be able to find them... The numbers you posted look familiar, national/ timken brand I believe.
    after some checking i found out napa is gonna be quite a bit more expensive so i'll try ab linn , thanks
    west central wisconsin
    There is a National 416282 on ebay now for 15.95 + 2.00 shipping
    DaveJ
    Jul 2009
    Louisville, KY
    Do you all remember if this National number is for the front or rear?
    National = National Federal Mogul?
    I need a front...Thanks!
    416282 is the rear.
    475384 is the front.
    Jul 2009
    Louisville, KY
    Thank you!
