Page 18 of 22 FirstFirst ... 8910111213141516171819202122 LastLast
Results 171 to 180 of 212
Thread: 6BT, CUCV Axled M715 Build
  1. #171
    I got it cut, the parts actually fit together and now it is on the truck for fitting. The student that did the cutting of the 1310 yoke didn't really go in a straight line, so it looks off a little. It isn't off at the ends though. You can also see in the pictures how much further back from stock the T-Case is now.
    Now to make the mounts, make sure it is square and then to figure out the other drive shafts.
    Well, after we actually weld this shaft up that is.
  2. #172
    May 2011
    N/W mississippi
    maybe a silly question but, to what points are you measuring to check 'squareness'?
    If there is any chance that my frame could be bent or tweaked, where would one measure to/from?
    I really don't know if my cement is even 'square' or flat enough and don't have 4 big enough jack stands that are the same to equalize things either..
    I'm thinking of using hockey pucks for body bushings so, will that added 'lift' effect linkage/shifting levers to the 205?
    In essence, how tight of tolerance does there need to be?
    Air-O-space (dial caliper) or caveman (16lb sledge)?
    E
  3. #173
    We measured and then centered the front pulley on the engine exactly in the middle. Then we built motor mounts to keep it there.
    We measured and then centered the transmission output shaft exactly in the middle of the frame rails. Then we built a mount to keep it there.
    I plan to make the 205 input yoke exactly parallel to the transmission output yoke. Then, have the passenger side drop the same as the stock 200.
    I am not going to worry about measuring between the frame rails for the tcase. The rear axle was set in with the pinion yoke verticle. The front axle was set up for 7° of Caster if I remember right. I actually think this was posted about earlier in this thread a few years ago.
    That answer your question?
  4. #174
    May 2011
    N/W mississippi
    I guess so. I wasn't sure if the 'stock' engine location was EXACTLY centered or off to one side or not..
    And these frames were not pampered all that much, so I don't know if I'm dealing with a 'tweaked' frame on mine or not.
    The previous owner said that he had all 4 wheels off the ground.. As in jumped it
    E
  5. #175
    We were finally able to get back to work on this project this week. The home made short shaft is now welded and best we can tell exactly square:
    We also spent the last 3 days getting a broken bolt out of the Getrag output yoke. Now we are back to making the 205 mount exact. Then we get to build some more drive shafts.
  6. #176
    Dec 2011
    central California
    I am still confused on how you mounted the front 60. you didn't use the factory mount because you are outside the frame. so what did you do?
  7. #177
    We used the stock M715 leaf springs and spring mounts. Under the frame. Then, once we got the castor set. We welded on a spring perch for the drivers side and ground the spring perch in the passenger side casing so it was the correct angle.
  8. #178
    We have a student that has completed his welding certification test and wants to do practical welding instead of just test plates. He loves the way the M715 looks and he asked if there was any welding needed to be done on the truck we are building for Sermis. For the past 2 months he has been spending 1 to 1-1/2 hours per day doing something to that truck.
    Cutting off the stock t case cross member mounts
    welding up the holes made by cutting
    fabricating new cross member mounts
    making NP205 mounts to fit the cross member
    finishing the short shaft
    mounting the 205 to the cross member
    welding the cross member mounts on
    cutting them off and welding them on the right spot
    re making his mounts so the 205 is level
    clearancing the cab floor so the 205 fits 8" behind where the cab floor has space for it
    making a shifter linkage holder to the Gertrag
    mounting the parking brake and tcase shifter
    making linkages for them
    I can't think of anything else right now.
    Anyway, here is how the 205 looks in there this morning after we pulled the cab off again:
    Here is how the shifter tunnel looks with everything hooked up and how close the brake is to the back of the cab:
    The student is now trying to make 5 drive shafts into 2 that will work for the totally different lengths we need. Then I will find something else for him to make.
  9. #179
    Sounds like he is learning some valuable automotive fab skills. some of them the hard way
    it looks like the drivers side t-case MT could use a gusset to keep it from fatiguing over time.
    67 #18820 mostly stock...
  10. #180
    Sep 2008
    Stevens Pointski, Wisconsin
    So unless I am missing something, a single stick with a t-bar, so either you have 2 high or 4 low?
    Scott
    '67 M715 '67 M725 '69 M726 (x2)
    "it's cheap and you get all you can shove in your pie-hole" --Kozmo 12-10-13
  1. My 1968 M715 build
    By Troop ISP in forum Modified Tech
    Last Post: April 2nd, 2015, 11:03 PM
  2. my build
    By chadriley5 in forum Modified Tech
    Last Post: January 23rd, 2010, 10:05 PM
  3. Another 4bt build
    By Burritoboi5 in forum Modified Tech
    Last Post: October 6th, 2009, 06:46 PM
  4. 68 m715/89 f350 build thread
    By res0wc18 in forum Modified Tech
    Last Post: September 2nd, 2009, 02:28 AM
  5. CUCV AXLES on the M715
    By joesco715 in forum Open Discussion
    Last Post: May 20th, 2007, 10:38 PM
