Page 30 of 39 FirstFirst ... 2021222324252627282930313233343536373839 LastLast
Results 291 to 300 of 388
Thread: Canadian build up !!!
  1. #291
    I checked and we dont have any of those pans left, I think they went to the scrap heep... We use to have this scrap metal guy come by every once in a while with this busted up jalopy of a f350 that would barely run, he'd get out and say ?Oyauboysgotanyscraptody", he didnt have any teeth so it was hard to understand him but we knew what he wanted. He was a nice guy though so we use to give him all our scrap aluminum and steel... How are you makin out? Have you decided anything?
  2. #292
    Jan 2008
    Montreal Canada
    The complete powertrain is out of the truck. I had to remove all sheet metal because it was pulled by a farm tractor. It was easy to removed everything and no rust was found anywhere. I clean the new engine and took measurements. With 1" cab lift ... i will need a true 3" more to get the new industrial engine on the right spot. I found a way to install my 4" snorkel ..... on the right fender into the cab with a 90 degree silicone coupler then right on the engine bay where the heater use to be. I will lost most of the compartment on the right but it's already not in use ..... so that's not a big deal losing it to have a true snorkel.
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  3. #293
    Sounds good, I cant wait to see the results. I take it you dont care that the body lines are gunna b a little off?
  4. #294
    Aug 2007
    Aurora, CO
    You may want to pull the numbers off of the hydraulic pumpthat is in the rear of the air compressor. What you may be interested in is the flow rate and psi setting. Depending on the psi and what steering gear box you have, you can blow seals in a hurry. Ive seen some of those zf pumps on Cummins in the upper 3000 at 15+gpm. The pumps can be set at different psi internally. my 0.02
    The air compressors are neat and useful. They just take some basic maintenance but the ideal OBA setup. Good score!
  5. #295
    Jan 2008
    Montreal Canada
    Quote Originally Posted by tndonor View Post
    For now i have found nothing on the casting ... so i really dont know what are the specs.
    M104A1 trailer
  6. #296
    Jan 2008
    Montreal Canada
    worked on the 205 this weekend. Complete rebuilt. Just need to grind the shift rail for the twin stick operation and fit the Np200 drum brake. I have to get a 32 splines rear flange and modify it to use a 1480 flange from a 5T truck.
    I should get the tranny in 2 weeks, so the first test fit should be by the end of the month .... the engine is ready to be painted.
    M104A1 trailer
  7. #297
    sweet...what is that 205 out of?
  8. #298
    Jan 2008
    Montreal Canada
    Quote Originally Posted by Warhammer View Post
    '70 Dodge divorced ....
    M104A1 trailer
  9. #299
    205 looks great! Who did you get your rebuild kit from?
    M715 Dreamer.
  10. #300
    Jan 2008
    Montreal Canada
    Quote Originally Posted by CE_TX View Post
    ..... Transparts warehouse in CA.
    http://stores.ebay.com/TRANSPARTS-AT...34Q2ec0Q2em322
    I have ordered my kit for the 93 dodge diesel np205 two years ago but everything that i needed was in the box ..... i even have extra gaskets and bearings. It was a very complete kit .
    M104A1 trailer
  1. My Build
    By spgirard30 in forum Modified Tech
    Last Post: February 2nd, 2016, 09:45 AM
  2. my build
    By chadriley5 in forum Modified Tech
    Last Post: January 23rd, 2010, 10:05 PM
  3. #37 build
    By FlatlinesUp in forum Modified Tech
    Last Post: December 13th, 2009, 11:02 PM
  4. Another 4bt build
    By Burritoboi5 in forum Modified Tech
    Last Post: October 6th, 2009, 06:46 PM
  5. Some Build Pics
    Last Post: July 13th, 2007, 03:12 PM
