Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: elohim1 : Radiator in the bed ??
    Default barrman :
    Re: Radiator in the bed ??
    Post by barrman on Nov 2, 2006, 9:59am
    Here is the best picture I have of the fan here at work. It was taken over a year ago, but you get the idea.
    Default barrman :
    Post by barrman on Nov 2, 2006, 10:00am
    I still have enough room in front of the fan to use a short socket and a 3/8" ratchet drive to install the bolts.
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on Nov 2, 2006, 6:52pm
    Quote:
    I've got a 454 and a tilt front- I fit a stock Ron Davis dual pass rad. with two puller fans- fabbed a custom mount. Pass. fan motor misses alt. by about 1/4 inch. Works great though. Gimme your e-mail and I'll sent pix if it helps. Won't be till next week though, I'm headed to Mex this weekend
    Yes, please send pics of this tilt setup to : elohimfirst@msn.com
    Thanks
    Good info. gents.
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Nov 2, 2006, 8:27pm
    sorry boss, got so friggen busy with DieHard4 filming today...I'm going in tomorrow to work on 715, i'll get them tomorrow...
  5. #15
    May 2004
    Anchorage, Alaska
    Default 40grit :
    Post by 40grit on Nov 3, 2006, 4:53pm
    ok, here's a bunch...
    front view, ground level
    [img=http://img292.imageshack.us/img292/5607/coresupport002qc6.th.jpg]
    top view
    [img=http://img126.imageshack.us/img126/7586/coresupport003ty0.th.jpg]
    passenger side rear view
    [img=http://img293.imageshack.us/img293/4955/coresupport004ht4.th.jpg]
    driver side rear view
    [img=http://img527.imageshack.us/img527/4599/coresupport005aw2.th.jpg]
    yet another view
    [img=http://img170.imageshack.us/img170/7326/coresupport006el6.th.jpg]
    radiator I'm using, with Flexilite 292 monster fans ( 31x19 universal Gm rad)
    [img=http://img527.imageshack.us/img527/2104/coresupportsc1.th.jpg]
    no put together pics, but the rad fits in front, about 3" further forward than stock with the fans behind it...leaves about 1" to front of water pump serp pulley...still has room for auto tranny cooler in front if I decided to change down the road...
    supports are made of steel framing member, cost $11 for 10' section, cut a few pieces out, bent some in half lengthwise and used them for front supports, with a thin strip of rubber, it fits perfect around tanks on radiator, just need to fab top and bottom brackets, and drill holes for fans to mount...
  6. #16
    Oxford, Ohio 45056
    Default elohim1 :
    Post by elohim1 on Nov 3, 2006, 9:29pm
    Much appreciated 40grit !!!
  1. elohim1 : On board air with GM compressor ??
    By Elohim1 in forum PseudoZone - Mod Tech Archive
    Last Post: December 15th, 2009, 09:24 PM
  2. elohim1 : BBC header selection, what did you use?
    Last Post: December 15th, 2009, 08:48 PM
  3. elohim1 : Serpentine system and ON board Air ??
    By Elohim1 in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:29 AM
  4. elohim1 : What is the spacing on the points for a 230?
    Last Post: November 11th, 2009, 06:09 AM
  5. elohim1 : Which 502 motor should I use?
    Last Post: November 11th, 2009, 05:46 AM
