Results 1 to 3 of 3
Thread: 10k garwood winch from rear PTO 205?
    Default 10k garwood winch from rear PTO 205?
    Is it possible (keeping in mind I'm hard headded and have lots of tools) to mount a 10k Garwood in front and run it from an attached np205 that has a rear facing PTO?
    I'm not familiar w/any PTO winch setups and would appreciate any pics/diagrams (or links to them) to help me figure out what I'd need to make this happen.
    Thanks gents!
    Britt
    FL^
    There was a former member that had 10K garwoods at both ends of his M715. A different pto to run each though.
    All you need is a shaft that turns to power the winch. A rear facing pto could be made to work with triple row chain and sprockets to get the power going to the front.
    most pto outputs can be swapped from front to back facing. Running a front mounted winch from a rear facing pto isn't impossible, just lots more engineering than you should have to do. I will call you in a little bit. Snakeater
    COWBELL, you need more of it
  1. jeepcj : Rear mount pto winch
    Last Post: November 12th, 2009, 01:50 AM
  2. rear winch
    By M715AKACHARLIE in forum Modified Tech
    Last Post: March 11th, 2009, 02:27 PM
  3. Garwood winch
    By 646dan in forum Modified Tech
    Last Post: February 28th, 2008, 12:33 AM
  4. Rear Winch Install w/ Pics
    By Jay Dog in forum Modified Tech
    Last Post: August 4th, 2007, 12:48 PM
