Thread: stock plug wires?
    Default oil?
    i have a mess of ignition on my truck there will be post about that to follow.
    first ... i have two distrubitors that came with the truck and a set of water prof plug wires. how do you check the wires to see if there any good?
    The only info in the manuals I can find says to inspect visually and to check continuity...better than nothing I suppose...
    Use a ohm meter (resistance) check each wire and all you can do is assume that if one or two show dramaticly more resistance, they probably are bad.
    Louisville KY
    Speaking of resistance, I was working on my ignition a few months back and figured I would ohm-out the dist. cap from the inside to where the plug wires attach on the outside just for kicks. I was expecting little to no resistance but when I measured it, it was quite high (been to long to remember the exact value). I was suprised by my findings and initially wondered if I had a problem. Anyway, the truck runs fine so I guess it is suppose to be that way.
    thanks for info........ figure as much didnt know though first military truck and 24v system i've worked on
    "An axe. A real axe. An 'I'm out of ammo, let me grab the axe', type of axe!" steelsoldier FrankUSMC
    I was surprised about the resistance in the distributor cap also, but someone posted quite a while ago that this resistance is intentional. I don't remember the values either, but it's not a problem with the cap.
  1. Spark plug wires
    By Mater715 in forum Stock Tech
    Last Post: August 2nd, 2008, 05:47 PM
  2. plug wires
    By cnewman425 in forum Stock Tech
    Last Post: August 15th, 2007, 09:58 PM
  3. Wiring diagram for spark plug wires - HELP!
    Last Post: March 22nd, 2007, 12:54 PM
  4. Stock plug wires
    By knave in forum Stock Tech Archives
    Last Post: May 17th, 2004, 04:52 PM
  5. Using Civilian plug wires on the Military Distributor
    By brute4c in forum Open Discussion Archives
    Last Post: April 9th, 2004, 03:52 PM
