Thread: maddawg308 : Size of fron and rear axle u-bolts?
    Default maddawg308 : Size of fron and rear axle u-bolts?
    Post by maddawg308 on Sept 2, 2006, 2:13pm
    Does anyone know the standard size nomenclature of the U-bolts for the front axle, and the two non-bent ones for the rear?
    Re: Size of fron and rear axle u-bolts?
    Post by maddawg308 on Sept 3, 2006, 11:25pm
    BTT. Can anyone help me with this? Want to know the right size so I can get the parts at NAPA without cutting them off the truck first...
    Default tacomainoh :
    Post by tacomainoh on Sept 3, 2006, 11:29pm
    uh.
    Just measure the thickness. I got Ubolts for a 3/4t Chevy, they worked fine for me. ? Not that helpful LOL
    Washington State
    Default fisherman :
    Post by fisherman on Sept 4, 2006, 11:03am
    I just read this, if you can wait a few minutes until I have my coffee I'll go out to the shop and measure mine, I just installed them a couple weeks ago. Thanks for the ubolt plates Tacoma. Your brushguard is looking awesome, too bad you won't see it for awhile.
    Washington State
    Default fisherman :
    Post by fisherman on Sept 4, 2006, 11:46am
    OK coffee done, much better. Front ubolts I bought mine from Napa are 2 3/4 inch width for same width axle tube by 71/2 " length, I threw away the boxes so I don't have a part #. The rear ubolts came from AB Linn when I bought new leafs, they measure 31/2" axle tube width by 81/2 inches in length. I added the bend via BFH and a large vise. Remember torqe em, drive, torqe em drive, torque em, drive then double nut em. Good Luck
    Post by maddawg308 on Sept 5, 2006, 8:22am
    Thanks for the help, guys!
  1. maddawg308 : Going nuts about my bolts...
    Last Post: November 11th, 2009, 05:10 AM
  2. Axle U-Bolts
    By scottsmyth in forum Stock Tech
    Last Post: July 25th, 2009, 05:00 PM
  3. Rear axle u-bolt size
    By Jester in forum Stock Tech
    Last Post: October 30th, 2008, 04:48 PM
  4. Questions about the rear-rear axle
    By Brian Sisson in forum Stock Tech Archives
    Last Post: May 21st, 2004, 08:06 AM
