Thread: bluesman2a : The bestest brake bleeding tool EVER.
    Atlanta, Ga.
    Default bluesman2a : The bestest brake bleeding tool EVER.
    Post by bluesman2a on Aug 20, 2006, 12:57am
    Normally I just gravity-bleed everything. But on the new project, with the Mico-Lock and ALL that new line, that was taking for-EVER. I remembered a post from Pirate a while back.
    Took a 1/4" plate drilled it and tapped for an air fitting.
    Clamp this to the top of the MC (if it's a dual reservior, pit this over the side you want to bleed).
    IMPORTANT!!!!! Before you hook the air up, regulate your flow down to like 5 PSI, you don't need much pressure to do this.
    Fill the reservoirs and put on the chuck you will hear air leaking out, that's OK.
    Go crack the bleeder, it will start flowing immediately. Essentially you bleed like always, but no pumping the pedal.
    One way to improve this would to put some gasket material on the plate or get an extra MC rubber cover from the Help! section. Didn't have any of that, but it still worked fine!
    Default saxon :
    Re: The bestest brake bleeding tool EVER.
    Post by saxon on Aug 20, 2006, 10:01am
    Bluesman, that is cool,being's I'm always the lone ranger on these projects. I'll have to remember this one! Thanks
    Default robertcowan :
    Post by robertcowan on Aug 20, 2006, 1:36pm
    me toooo THANKS A BUNCH GREAT TECH YOU TAUGHT AN OLD DUDE SOMETHING. and a piece of inner tube will make a good rubber seal........
    BOB
    Default gregolma715 :
    Post by gregolma715 on Aug 20, 2006, 9:58pm
    Neat. There's always the Motive Power Bleeder if fabbing is out of the question.
    http://www.motiveproducts.com
    Default ewob53 :
    Post by ewob53 on Aug 21, 2006, 9:14pm
    I've done the same kind of thing by mounting a rubber valve stem from a tubeless rim on top of an old master cylinder cover. It was pretty handy to have laying around.
    EWOB
    Default kaiser715 :
    Post by kaiser715 on Aug 22, 2006, 9:34pm
    never seen that. I got one of the mightyvac bleeders. works pretty good. That looks better -- and cheaper.
  1. bluesman2a : SOLVED: Strange brake problem...
    By bluesman2a in forum PseudoZone - Open Archive
    Last Post: November 12th, 2009, 03:07 AM
  2. Brake Bleeding
    Last Post: March 13th, 2009, 10:04 PM
  3. Rear Brake Bleeding
    By Warthog in forum Open Discussion
    Last Post: April 15th, 2008, 11:41 AM
  4. Brake bleeding problems
    By fng in forum Modified Tech
    Last Post: October 29th, 2007, 08:21 PM
  5. Pro Tool Disc Brake Conversion Price
    By kalikraven in forum Open Discussion Archives
    Last Post: February 15th, 2004, 12:55 PM
