Thread: rumplecat : Power Steering Pitman arm????
    Default rumplecat : Power Steering Pitman arm????
    Post by rumplecat on Jul 20, 2006, 12:21pm
    I just ordered a rebuilt steering box and power steering pump for a 1991 FSJ, my brother in law works in a parts store. I am sure the steering box won't have the pitman arm on it, can I use the arm off my stock box?
    Thanks,
    James G.
    Default compexp :
    Re: Power Steering Pitman arm????
    Post by compexp on Jul 20, 2006, 12:35pm
    Don't think so, but you can use an FSJ one.
    Post by brute4c on Jul 20, 2006, 2:05pm
    Nope, stock arm wont work...compexp has your solution though...FSJ is it!
    Default rumplecat :
    Post by rumplecat on Jul 21, 2006, 5:16am
    Any body got a '80 model FSJ pitman arm they are willing to sale?
    James G.
    Default jeepcj :
    Post by jeepcj on Jul 21, 2006, 6:29am
    I hqave one from a 74 CJ with power streering. I don't know if they are the same
    Default compexp :
    Post by compexp on Jul 21, 2006, 8:50am
    good question - maybe check with a parts place to see if the part numbers are the same.
    Default grantshire :
    Post by grantshire on Jul 21, 2006, 10:15am
    CJ pitman arms will fit on the steering box but are smaller (less "beef") and slightly shorter (very slight difference in length). I would not advise using a CJ setup on a M715. I have FSJ Dana 44's under my CJ8 and a 2000 S10 saginaw steering box (option to FSJ box). I moved the steering box forward 1.5" (M.O.R.E. bracket) and still had to use the smaller CJ pitman arm and upper drag link joint (custom, turned FSJ drag link) to clear my tie rod. Works great on a CJ but not enough "beef" for a big Jeep.
    Default jeepcj :
    Post by jeepcj on Jul 21, 2006, 5:13pm
    I also have a scout pitman arm. I know it's the same spline and about 4" longer than the CJs
  1. power steering
    By ronzello in forum Modified Tech
    Last Post: March 5th, 2010, 03:24 PM
  2. power steering
    Last Post: November 26th, 2009, 12:51 PM
  3. Power steering- pitman arm
    By Bobmog in forum Modified Tech
    Last Post: July 9th, 2009, 11:45 AM
  4. power steering
    By desertfox in forum Modified Tech
    Last Post: May 12th, 2009, 01:45 PM
  5. Power steering
    By jfharris in forum Modified Tech
    Last Post: March 25th, 2007, 09:33 AM
