Results 1 to 10 of 11
Thread: opie744 : More tire tube questions
    Default opie744 : More tire tube questions
    Post by opie744 on May 8, 2006, 4:11pm
    The guy at the big tire place around here that does semi truck tires ect says that the company he gets his tubes from says that 11.00x15 tubes will work w/my new XL's...this doesn't sound right to me, am I crazy?
    Should I do it the slow way and order the tubes? I wanted to get the new tires on this weekend...
    Thanks.
    Paul
    Default robertcowan :
    Re: More tire tube questions
    Post by robertcowan on May 8, 2006, 4:17pm
    I ,VE got some nice stock innertubes and liners. 10.00 each. bob
    Default socal715 :
    Post by socal715 on May 8, 2006, 4:20pm
    They will work. They just stretch out. The real important thing Opie is to make sure the valve stems are the correct. Double check them.
    The tubes i order from International tire and tube are 15/16's.
    Default opie744 :
    Post by opie744 on May 8, 2006, 5:04pm
    For radials?
    Default opie744 :
    Post by opie744 on May 8, 2006, 5:05pm
    How do I know what is correct and not correct?
    Default mgmorrison :
    Post by mgmorrison on May 8, 2006, 7:09pm
    I'm guessing you are talking about the 11x15 tubes rather than the stock that Bob was offering up...
    Martin
    Lone Pine, CA
    Default luckypabst :
    Post by luckypabst on May 8, 2006, 7:20pm
    1100R15's in mine. I believe they were printed as 1100R15/16. Supposed to be very common for lowboy tires (whatever that means).
    Default binfordm715 :
    Post by binfordm715 on May 8, 2006, 9:13pm
    The tubes I ordered for my XLs had a range of sizes on them, such as 9.00-11.00 15/16. The two keys are 1) make sure they're radial tubes and 2) like Socal mentioned, make sure you get the right valve stem. I guess "right" means you can get to it when it's mounted!
    Default socal715 :
    Post by socal715 on May 8, 2006, 9:34pm
    Also, make sure its a metal valve stem instead of a rubber stem. The metal sticks out further.
    Default opie744 :
    Post by opie744 on May 9, 2006, 7:02am
    Thanks for the help guys
  1. alosix : Tire Tube?
    Last Post: November 12th, 2009, 12:17 AM
  2. teking : Tire tube
    By teking in forum PseudoZone - Open Archive
    Last Post: November 11th, 2009, 01:21 AM
  3. agengr : International Tire and Tube
    Last Post: November 11th, 2009, 12:45 AM
  4. Tube and flaps?
    By b-tyme in forum Stock Tech
    Last Post: May 13th, 2009, 02:31 PM
  5. Tire Questions
    By jlogan in forum Open Discussion
    Last Post: March 14th, 2007, 04:13 PM
