Page 21 of 39 FirstFirst ... 111213141516171819202122232425262728293031 ... LastLast
Results 201 to 210 of 388
Thread: Canadian build up !!!
  1. #201
    Oct 2009
    Methuen, MA
    This is just an amazing build, thanks for posting, it's very inspiring
  2. #202
    OMG this a a very very nice build M715 congrats
  3. #203
    Jan 2008
    Montreal Canada
    thanks .... and still not finished !! Been working hard the past two weeks !! I will updated the pics next week end
    Rockwells / Cummins / 3053A
    Combat wheels on 395 XML
    M104A1 trailer
  4. #204
    Hey buddy i am planning a j10 build was wondering what kind of motor mounts you used and what kind of mods did you have to do under the hood on the body??? Thanks alot
  5. #205
    Jan 2008
    Montreal Canada
    stock first gen cummins engine mount ..... and no mod at all under the hood for the body .... but you need to run electric fans .... If you want to keep the stock mechanical fan ... cut into the rad support and move the rad up front a good 2" .... and everything will clear
    M104A1 trailer
  6. #206
    Jan 2008
    Montreal Canada
    I just went to my US adress this morning and i received two defrost vent from VPW and my twin stick and handbrake boot .... Since i remove my injection pump ... i will be able to bring my power back because i can lower the idle now the screw is no longer jammed. More pics to come by this weekend
    M104A1 trailer
  7. #207
    Jan 2008
    Montreal Canada
    no pictures but here's some updates ---)
    I have heat ... lot of heat ... maybe even too much !!
    Working defroster
    Received an HID lighting kit for my birthday ... 55 watts low and high H4
    Freshly installed non oem wood sides ... just need to be painted tomorrow
    New project ..... 4" snorkel !!
    M104A1 trailer
  8. #208
    Jan 2008
    Montreal Canada
    Forgot to tell the the truck is now back on the road .... I tried the rear locker doing a nice 360 in front of the driveway !! That truck is sick ... i never taught it could be doing a 360 so easilly !! Next summer it will receive new injectors ( 80 hp ) and i hesite between tranny upgrade ( shift kit ) or manual swap !!
    M104A1 trailer
  9. #209
    What other mods have you done to the motor besides the 3200 governor spring, fuel pin, and turning the fuel screw?
  10. #210
    Jan 2008
    Montreal Canada
    Quote Originally Posted by Warhammer View Post
    Nothing more then that .... the gov spring is not even installed because i doesn't need it ... running 70mph with that truck is more then enough. Next summer will add 80 hp injectors and finished my intercooler setup. Since here we are having 30 and down degree i dont need the rush to instal the new setup that will consist of a new bigger radiator and air intercooler instead of the water setup i was supposed to install.
    M104A1 trailer
  1. My Build
    By spgirard30 in forum Modified Tech
    Last Post: February 2nd, 2016, 09:45 AM
  2. my build
    By chadriley5 in forum Modified Tech
    Last Post: January 23rd, 2010, 10:05 PM
  3. #37 build
    By FlatlinesUp in forum Modified Tech
    Last Post: December 13th, 2009, 11:02 PM
  4. Another 4bt build
    By Burritoboi5 in forum Modified Tech
    Last Post: October 6th, 2009, 06:46 PM
  5. Some Build Pics
    Last Post: July 13th, 2007, 03:12 PM
