Page 3 of 19 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 184
Thread: AMC 360 swap
  1. #21
    Trenton, all you need is like 14 roller bearings for the swap, let me know when you're ready I'll get my guy to get em.
  2. #22
    Jester Guest
    Quote Originally Posted by saxon View Post
    I need to get a "guy".
    Thanks, I will let you know.
  3. #23
    Washington State
    John, the gear guy gets the nod.
  4. #24
    Jester Guest
    Quote Originally Posted by fisherman View Post
    wooo hoooo I got a guy
  5. #25
    Jester Guest
    So the weekend was spent pulling off all the front clip and getting the motor ready to pull. Hopefully get some pics up soon.
  6. #26
    Jester Guest
    What it looks like today.
  7. #27
    Winlock, WA
    Good start!
    Now, if ANY of those body bolts are junk, replace them!
    Also, running a tap in those thread to clean them up is nice.
    I like to make a point of doing that if I know I will be messing with the front clip fairly often. Main reason why I have a couple boxes of brand new bolts just for that purpose.
  8. #28
    Jester Guest
    Quote Originally Posted by Hammer View Post
    Good start!
    I was really surprised that I only broke 4 bolts. Two in the font valance and both sides on the bottom of the fender where it connects to the rocker. I put all the hardware into little bags and labeled them with where it came from. Also labled all my wires that I disconnected.
    So far so good.
  9. #29
    Winlock, WA
    PB Blaster is your friend for those bolts.
    I have a personal peeve against pulling apart front clips. Done it on a lot of FSJs now, and those bolts are nothing but problems!
    My new ones are nice and shiny and will last a long time, and guess what? They come out easy even a few years later!
    If you reuse the stock type, a little anti-seize is well worth it.
  10. #30
    Jester Guest
    Since 90% of them are the same size, I will prob just go buy a box of new ones. Maybe stainless for the ones that really get lots of water. A little anti seize on everything too.
    And before the flames start, yes I know that stainless does not have the strength of normal alloy fasteners. I never use stainless in a critical area - if I need strength I use grade 8.
  1. Body Swap vs Drive Train Swap
    By ChalkOutline in forum Modified Tech
    Last Post: April 22nd, 2010, 07:55 AM
  2. 4.0 swap
    By no1rifleman in forum Open Discussion
    Last Post: February 10th, 2010, 01:35 PM
  3. 6.2 swap
    By militarytrux in forum Modified Tech
    Last Post: April 11th, 2009, 01:41 PM
  4. V-6 swap
    By halftrack78 in forum Modified Tech
    Last Post: January 9th, 2009, 09:59 PM
