Thread: Steering Column Rebuild
    Default Steering Column Rebuild
    I have been asked to post the rebuild instructions of when I fixed my column.
    The diagrams and instructions are in the -34 tech manual, Chapter 15. You will need to remove the steering wheel and then remove the column.
    The lower bushing and the boot where torn. I ordered the bushing from Memphis Equipment for ~$30 and the boot kit from http://www.jeep4x4center.com/jeep-st...herokee-sj.htm. Item #4 ~$11
    The boot kit is not an exact fit and needs to be modified. The shafts are a different shape.
    Here are the old parts layed out
    This is the lower bushing that I replaced. Memphis Equipment has new ones.
    This is the new kit and the old parts
    Make sure you re connect the horn wire
    The horn wire slips into the top bushing
    I greased the new lower bushing. I hope it helps
    Continued ..........
    Continued..........
    I greased the new bushing. Hope it heps.
    The new buttons are attached
    Make sure you grease the joint
    Putting the joint together. This picture was taken before I knew I had to trim the boot.
    Reassemble per the instuction manual.
    You may want to replace the rag joint at this time. It is easier to do it now while the column is out of the truck.
    Good Luck
    Another great write up...THANKS!!!
    Thank you for the write-up. Very good to see the details before tearing into the column.
    Auburn, AL
    Nice!!
    Jon,
    Is there any way to compile all of these tech writeups into a file? Might save some repetitive questions from making it on the boards. Using a search doesn't always make finding information easy.
    Snuffy
    If/when I have time, yes there is.
    Washington State
    Nice write up. I performed the same task with the new boot trimmed in the same manner. However I was lucky and did not need the new bushing. Very nice.
    SF Bay Area, CA
    Thanks for posting this write-up. Will need it in the future.
  1. Steering Column Parts
    By Barrman in forum Stock Tech
    Last Post: June 13th, 2008, 10:43 PM
  2. Steering column question
    By Roger1952 in forum Stock Tech
    Last Post: April 7th, 2008, 05:49 PM
  3. Steering column
    By archjr in forum Stock Tech
    Last Post: March 4th, 2008, 12:27 PM
  4. Steering Column Information
    By Grantshire in forum Open Discussion
    Last Post: January 3rd, 2008, 09:20 AM
  5. Steering column and headlight switch
    By fisherman in forum Modified Tech
    Last Post: October 28th, 2007, 10:55 PM
