I know you're already into it a ways, but I found that removing the front sheet metal isn't much work at all. Once that's done the engine is just a few bolts from coming out too.
Literally, I recall the entire front clip can be removed in one chunk with about 12-14 bolts, not including disconnecting the wiring and radiator hoses. Then all that's left is the fuel lines, bellhousing bolts, front pipe, motor mounts and throttle linkage.
I couldn't find an engine hoist that would lift anything high enough to get it out with the front sheetmetal on unless you used a chainfall and beam.
