Hey guys,
Apparently my ball joint assembly at the end of the clutch release rod (if that's what you call it) is worn out and the ball joint constantly falls out of it's socket. Though I think this part is not a stock item as this release system looks different from the one displayed in my 1967 military manual. My vehicle has a 4 cylinder Hercules diesel in it, which leads me to believe that the transmission is also not stock, thus leading up to the clutch release.
Memphis Equipment tells me they only carry stock items. Anyone know where I could start looking for this part? It looks simple enough. All I would need is the threaded-on ball joint assembly end piece as the other side looks just fine...so far.
Thanks,
Chris
