Use all the GM stuff, you need nothing off of the jeep. I swapped the cables so that they were on the passenger side. I am now working on getting my jeep brake handle mechanism to activate the new 14 bolt emer brakes. So far I have used a 75 ish chev monza clutch cable to jog around the transfer case, now it's just a matter of splicing the two together. I made a stand off bracket off the bolts that hold the front spring perch of the pass rear spring pack.(I have bolts now because of spring over) That bracket holds up the cable ends where the emer. brake cables meet. That's the stable end where it pulls from.
