Results 1 to 4 of 4
Thread: Another Big bucket Light Option
    Default Another Big bucket Light Option
    Kwai and I had hours and hours to talk while driving across the state last weekend. He mentioned he had seen a picture of a newer "composite" front light mounted on the back of a truck with a red lense in it. I didn't see the picture and wanted to look at it myself.
    So, I took a normal 4 bulb "composite" rear light off a newer MV, a normal 3 bulb "composite" front light off a newer MV and swapped out the lenses. What you get is a light bucket just a little bigger than the stock M715 small bucket tail lights with a huge easily seen red lense. Pretty neat. I think I will make a set of towing lights out if them.
    I couldn't get the lights to stand up like I wanted, but you can still get the idea. Here is a normal 4 bulb tail light on the left, a normal 3 bulb front marker light in the middle and a converted to rear use 3 bulb light bucket on the right. I didn't think to put a small bucket light in the picture, but the new light is about 1 inch bigger in all dimensions instead of several inches up and down bigger like you would get with the 4 bulb tail lights. This way you get the better visibility without risking them everytime you back out of the driveway.
    Thank oilcan for this trick. I saw it on his truck when I was in Ohio a while back. I have these lights mounted on the back of the trailer I am taking to the FE next week.
    Tim, what's up with the deuce fuel pump?
    I pulled it from the tank I got from Mr. Positive a month or so ago. I need to see if it works. If it does, I will put it in the truck and wire up an on/off switch for it. That pump will flood the Holley on the OA331. But, if my mechanical pump goes out on the road somewhere, I can flip the electric one on and off by hand to get myself home.
    If it doesn't work, then I will figure out a way to remove all the impeller/pump stuff and just have a p/u screen there so I can use that last 5 gallons of fuel my mechanical pump can't get to right now.
  1. Best power steering option for welded front end
    By fwdstuck in forum Modified Tech
    Last Post: December 7th, 2007, 01:27 AM
  2. Small Bucket Lights
    By Barrman in forum Open Discussion
    Last Post: February 19th, 2007, 09:10 AM
  3. Krob725's 230 fuel pump option
    Last Post: April 6th, 2004, 10:53 PM
