twin stick 205 Q's
I pulled out the actuating rod and did the grinding per 4x4 Off Road, abrubt cut on the end and sloping middle grind. I put it back together and tried it out. What I need to know is what grind on the rod does what. I was able to get 4 rear low without front engaged. I tried neutral rear and put the front into gear. It would seem to just nibble (just catching) when I turned it, so the front would solidly engage, but the rear drive would chug. I need to know what I need to grind more off of- thanks!! I would love to get this in ASAP so I can get my emissions done to bring it to the FE- gonz
Come and take it
